6.0 ls3 head, factory crank, 721hp@8000 e85
Recently finished a long running build, aim was 2.0hp per ci and we got there. Still retained factory alloy 6.0, factory crank and ls3 style rectangle heads. Made 721hp@8000rpm and 511ftlb@6800, without vac pump working 100% and 20w50 breakin oil, 1 3/4" conversion headers
big thanks to brenton marusic at thr development for building the engine, wayne from racecomp for the dyno
facebook video
https://m.facebook.com/story.php?story_fbid=10155629637439126&id=66406912 5
http://facebook.com/story.php?story_...6&id=664069125
facebook video
Alloy L98 6.0 alloy block 4.005
Factory 3.622 crank, knife edged, lightened, no reluctor wheel
Wiseco 12.5cc solid domed pistons, hand sculpted to chamber and bead blasted
Lunati billet i beam 6.125" rods
5364 casting rectangle heads, extensively ported (395cfm@850thou), decked 125thou, stainless valves 2.165 and 1.65, 15.0:1 compression, pac 1531x double valve springs 1.3" base, mast rocker covers
Cammotion LLSR 258/267 826/799 112+2 solid roller (measures 840/804 at valve)
Morel tiebars solid roller lifters
Jesel mohawk 1.7 rockers, 3/8 thickwall pushrods
Cloyes double row timing with flying magnet
Ls3 super vic hand ported
2" super sucker spacer
Custom 1000cfm quickfuel e85 carb, 110/110 jets
Arp main studs and steel girdle
Factory oil pump blueprinted and shimmed
Ati race balancer
Msd crank trigger
Bhp internal bypass mech fuel pump
Gz motorsports vac pump
Custom modified wet sump
Kurt urban front mount msd dizzy, hvc2
1 3/4 to 3" cae conversion headers
uxl 20w50 breakin oil
United pump e85
Ati race balancer
Msd crank trigger
United pump e85
Moderator
Received 1,836 Likes
That is severe! Nice nice work mang!
Man, you guys posting these 700+hp little guys. Makes me feel bad lol. Awesome motor man! Do you plan on spinning it over 8k as that's the peak right now?
Moderator
Dogs Bollocks you GOT to go to the mustang boards and post up 120 HP/L
Will go to 8300 out the backdoor on 1/4, just no point beating on a fresh motor for the sake of dyno numbers
Should push 740-750hp with lighter oil, vac pump @ 13psi and loosened up. I just wanted the e85 carb so can cruise it on the street. On roo16 big donkey dick scoop at track it will make some serious steam
Cheers guys, long time in the running. 2 years, 2 engine builders, 3 visits to the engine dyno! Seriously cant thank Brenton Marusic enough for killer heads and then the rest to back it up. Pipemax data was pretty much spot on the money, so shows homework pays off.
Will rev a bit more, if you go cammotion facebook page you will see the longer live video i posted. At 8000rpm still not laying over
Bit more work yday making it look pretty
Thank you for posting the build sheet. I'm going nuts trying to decide on a block. A new cast iron 4.005 6.0 block or an LS3 4.065 Aluminum block. Seeing what a 4.005 bore can do has me leaning towards the iron block. Although not using a power adder, I'd hate to bore that new block .060 over and loose wall strength. Stock Chevrolet cranks really hold up. Very impressive.
In process of sorting this out, I have a 6200 test convertor at the moment. Eventually thinking 6800 and 4.11s. But I have a dodgy lifter so need to pull motor down
