Finally got a chance to get the car on the dyno and I thought the numbers would be a little higher but with the Dyno being outside and the temps being in the low 90's with 90% humidity I guess it isn't to bad. There where some issues with the pickup wire on the dyno from the looks of it, also the care currently has 1 3/4 pacesetter headers and 2.5" exh I am wondering how much that is holding me back vs 1 7/8 and 3" exh. But overall the car feels strong and runs great.
All I can tell you is that my buddy gained 20 rwhp on his HCI 416 LS3 stroker 06 GTO, just by switching to a 3" catback. This was done on the same dyno about one year apart
Yah I was thinking it would pick up pretty well with a decent 3" exh, I've also been tossing around the idea of ditching the stock maf and doing a 100 mm tube with a ls3 card style maf might do it all at once and get it re tuned and see where its at.
Yep I hear ya. I do know my buddy runs the stock MAF, so I'm not sure how much of a gain that's worth. He went from 500 to 520 with just the catback change. He has 1 3/4" headers as well. His Mast 215 heads are what's holding him back from what he said.
Yah im not expecting to see any gains with the maf change just maybe make it more of a smooth transition to the 102tb. Speed engineering has 1 7/8 headers out now for the GTO with a 3" x pipe and exhaust coming at the end of the month so that's definitely on the list to swap out. He should look into the TFS 220 heads reworked by Tooley people seem to be doing pretty well with them.
His Mast 215's have been worked over as well. I forget who did it, but it was a big name from what I recall. His 125 shot more than makes up for any lack of n/a performance parts lol. Back when we were both running 100 shots he would pull on me a little bit. Im really curious how it would turn out now with me on a 150 and him on the 125 shot. His disadvantage is weight
Yah they are heavy for sure I got mine down to 3520 without me in it but that's still heavy compared to an F body.
That's pretty good for that car. Mine with no nitrous and about half a tank is roughly the same as yours, but mine is full weight plus an extra 100 lbs from the iron LQ9 block
Its still got the rear seats in it to thats another 45lbs at least. But they look way to nice to rip out. My 99 Formula was down to about 3300lbs without me in it.
470/430 is nice power if you ask me. What's your set up?
Its definitely nice power but it still has a little more on the table I think when it comes to exh. The setup is TFS 220 as cast heads EPS 230/238 CAM 113+2 LSA port matched fast 102 NW 102 TB Pacesetter headers 2.5" exh 25% UDP.
Very nice. Those heads can still be milled and ported, plus 1 7/8 headers w/3 inch electric cut outs should be worth around 20whp, hell might even get you in the 490s... Your in a great position to do a comparison, show how much head work is really worth.
I'm planning on replacing my water pump with electric water pump when I do my heads cam, I've been told it free up 5-10whp. I'm going to need it bc I had a mild cam spec'd out for me.
