Not real happy!!
what did the car dyno cam only?
that setup should definetly peak above 5700rpms. hopefully it is just the headers causing the low numbers. it is hard to believe that the headers are really gonna give you 35 more rwhp, but maybe.
do you have a cutout in your exhaust? i've seen y-pipes eat up 20+rwhp before. cutouts in the y-pipe might be something to consider.
Just figured I would mention it.
MAC's actually do better that LT's on top, it is down low where the LT's fair better. I doubt that the LT's will give you the extra 35 horses over Macs but it would be nice if they did.
Good luck, Shawn
All this dyno number BS,I dont believe any of it for a minute..
Why is it when someone else tunes or tries these setups they are down 10 20 30 40 RW,I'll tell ya why because its BS.I've been to alot of shops and one thing I can tell u,ESP's dyno is perfect and realistic.
Those guys just dont fudge or play games---->There HONEST about #....
I would look at the geometry of the valvetrain just for S&G but I wouldnt waste money on headers.
Shawn
Just trying to help
BTW Eastsides dyno is about 10hp lower than the dyno`s on long island here. Thats why I post my numbers from there.
I am curious as to why you went with a bigger TB and intake. It was not required You are not moving enough air to overtake the stock throttle body and intake. The stock injectors also had enough fuel to power your modifications. I am also curious as to the rest of your cam specs. Did you get a big enough cam for the LSX intake to improve your power range. There are several reviews out there now in Hot Rod Mag, and popular hot rodding, and Chevy Performance showing the gains with this intake, but it has to have a big enough cam. I agree and do not think the headers were the cause here. You are not bringing enough air into the engine for the headers to be a problem. If you are getting to 5700 RPM and then flatting out, it seems to me that the engine is either making all of the power that it can based on the amount of fuel and air you have coming into the system or you have something else that is not functioning properly.
In regards to the 7000RPM. If this is not a double spring setup on your valve train, you could be experiencing some valve float. If this is the stock valve springs or not a double valve spring you would be wise to keep it under 6500.
The comments listed here are an opinion in an effort to assist. This is not an attempt to start some flaming war or something.
Good Luck
FWIW,I shift at 6500 1 to 2 and 6400 2 to 3..
I think your fine,Look at the graph on this cam and u can see it hit 6300 and then falls off at 6500...
Your setup holds it longer so shift the car at 6700,thats where it falls off.
That is PERFECTLY normal and actually a good thing.
10RWHP from 5700-6200rpm is good. Holding it to 6700 is VERY good.
Broad flat powerband is what you WANT!
I am not sure I understand what you are complaining about
can I have your car??
