TEA stg 2.5 LS6 heads and G5X4 dyno and track times within.
My combo consists of a 373 short block, 3.905 bore, 3.9 stroke, G5X4, TEA stg 2.5 LS6 heads and a Th400 with a TCT converter. All dyno's were done on Hooser 29in drag slicks with a 12 bolt with 4.33's in the butt. The motor has 12.2-1 compression and was ran with 28* of timing. The car made 472.2rwhp at 6800 and 513.4 rwtq at 3800. My car has a 3400lb race weight and in 90* air went 10.80@126.7 on a 1.52 60ft. We were having a hard time hooking it up due to old tire I guess. This is also a N20 setup everone as was the converter. I just wanted to let everyone know about these great products and companies. I will not be making anymore new bests as a rod decided to leave the block last night. So if your looking for heads call TEA, a cam call LG, you need a converter call TCT. Back to retirement for me.
Originally Posted by -=Merlin=-
Anymore info on the cam?
Whats it designed for?
How much did the heads run you?
Great results!!
Great results!!
It was a forged motor. The cam specs are secret, I don't even know them. I do know it's a big block cam i.e ment for 422+ cars. The heads I got through brian Tooley as a sponser deal.
Better yet, put em on Shawn's car with some flycut pistons and see if that thing will go low 10's. Need to borrow a piston notching tool? Let me know.
Sorry for the rod issue, if it wasn't for bad luck you would have no luck at all.
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
I have no clue what the cam specs are, but I have crap for vacume at idel. I pulled the head on the ofending side everthing looks good except the exhaust valve. It seems the wrist pin failed causing the rod to brake and put 2 very big holes in the block. I will NEVER buy a JE piston again. 25 passes and BOOM!
![Aug2](https://ls1tech.com/forums/images/smilies2/aug2.gif)
![Disgust](https://ls1tech.com/forums/images/smilies2/disgust.gif)
Also I just wanted to say the Speed Inc did all the tuning and helped me sort out a lot of problems I had in the begining. They are a top notch shop.
It all depends on if my crank is reusable, looking unlikely though. Im not about to drop 2K on another crank. If thats the case I will see how this LS2 block thing pans out and just toss in a stock crank with some good rods. Drag racing is like a crack habbit to me, despite better judgement I always come back for more. I just wish I could have sprayed that motor as it was a N20 motor with a N20 converter. I think mid to low 9's would have been no problem.
If anyone has any Q's about the combo shoot me a PM. I can't say enough about these heads. The car ran like it was on spray with them, and it was acused (sp) of it every time I ran it! P.S all my 10.8 passes were in 2300-2400 DA of air.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
About what would that number come out to be in a 6 speed car. Would Tq controlable on street tires. Could I drop it on the freeway at about 50mph and keep it going straight.
