My Absolute/ G5X3 dyno...
Not a high as I would have thought since I made 422 HP with the X2 and a set of Jays old heads. Heads are stage 2 5.3s with 11:1 compression. Its not too bad.
Ignore where it says GTO.. dyno likes to use random names
Very true.
Absolute 5.3 s2 heads, TSP 231/237 cam, TCS 4200 stall, Moser 12 Bolt w/3.73's,True Duals,
423RWHP and 383RWTQ with a ls1 intake and stock TB
https://ls1tech.com/forums/dynamometer-results-comparisons/213862-absolute-5-3-heads-tsp-231-237-dyno-results.html
AS Stage 2 5.3's & TR 224 Cam Dyno Results
Peak hp 432 HP
peak TQ 410
https://ls1tech.com/forums/dynamometer-results-comparisons/203640-stage-2-5-3-s-tr-224-cam-dyno-results.html
These heads are cnced so they are all pretty much the same. With all the talk about these heads lately Im just wondering how how these guys are making all this power.
Country can ya tell more about your setup
exhaust etc
Induction
Fast Toys Ram Air
Holly Powershot filter
TSP smoke clear lid
Whisper MAF ends
Absolute Speed 78 mm TB
BMR TB bypass
Fueling
FMS 30# red top injectors
Walboro 340 intake fuel pump
Engine
LS6 block
Absolute Speed Stage 2 heads
~ 2.04/ 1.60 Rev valves, Comp 977 springs, titanium retainers
Hardened pushrods
Comp R lifters
Yella Terra Rockers
LG’s G5X3 cam
Rollmaster dual chain w/ torrington bearing
Diamond forged pistons 3.905 bore
Diamond Pro Select Plasma Moly file fit rings
Eagle ESP 6.1 H beam rods w/ .927 floating pins
ARP rod bolts
ARP 12 pt. head studs
ARP main studs
6.0 crank
Stock gaskets (graphite head gaskets)
Thunder Racing ported and shimmed oil pump
ASP under drive crank pulley
Federal Mogul main and rod bearings STD
Hypertech 160* t-stat
Poly motor mounts
Accurate Machine Works PCV catch can
Exhaust
Kooks 1 7/8 stainless headers
Kooks 3” off road Y pipe
Hooker catback
Deleted AIR system
Drivetrain
Spec stage 3I
McLeod adjustable master
Factory Hurst shifter
Poly trans mount
Computer
Dyno tune by Rev Xtreme
Suspension
Kenny Brown double diamond subframes
Dragin Motorsports LCAs
SLP Eibach springs
I know you would like to see more power but its hard to complain about a 425rwhp car
I wonder id I could do a back to back with a good dual vs a Y and catback at Rev Xtreme... I still have my duals...
I got my duals over 2 years ago. I gain 1.5 tenths at the track over my open cutoutwhen i had a 3in custom y pipe. I wish I had dynoed but my car has alwasy made great power since I put the duals on. I noticed alot of the higher hp cars have duals. What kind of mufflers were you runing on your duals?
