Has anyone seen a Ferrari Enzo dyno sheet?
Well they only run a 12.9. What do you expect them to dyno? I'm sure they are fairly light. The enzo's should be considerably higher than the 360 since they are quite a bit faster. Sorry I have no numbers, but you can't compare the 360 to the enzo as far as power is concerned.
Originally Posted by slow14U
According to motor trend, it trapped 133 mph. Put some sticky tires on it and it is a mid 10 sec car.
Brandon
Originally Posted by xfactor_pitbulls
Put sticky tires on it and you might see a big boom from the drive train. Its not a drag car.
Brandon
Brandon
Brandon
Brandon
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
F-body's aren't drag cars either. Put sticky tires on one from the factory and .... BOOM goes the dynamite!
Originally Posted by v8maro
If you've got enough $ to buy an enzo and put sticky tires on it, you've got enough money to build up a broken rear.
