PRC Street $849 Heads DYNO RESULTS
#46
For the guys that's wondering how these heads will do with the MS3, I'm getting the car tuned right now at Vette Docs in NY.
My setup is PRC LS6 stg1 heads, MS3, Kooks 1 3/4 w/offroad pipes., ASP pulley, Halltech stinger, ported ls6 oil pump, FAST 36lb inj. and stock TI exhaust. The car is a 03 Z06.
Baseline without tune was 430rwhp. After a little tweak, it put down 461/409. There's still more tuning to do, but so far it's looking prety good. I will post up final numbers and graph when it's all done.
#47
LS1Tech Premium Sponsor
Great results NeverT00Fast, can we get a dyno sheet posted?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#48
Thanks Jason, I spoke to you a couple of times over the phone regarding my combo. I will def. post up the sheets tonight after it's all done. Also want to take this chance to thank all you gents at TSP for your help on my project, everything went very smooth. And a special thanks to Jon for making sure the injectors showed up for the tune, as well as his help on rest of the parts. ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Tom
Tom
#50
Final numbers. First run is untuned and the final run.
Special thanks to Carmen at Vette Doctors for working his magic on tuning this badboy. Before the tune, the car was barely idling but now it's very smooth. It still bucks under 1500rpm, but that's just the nature of a cam like this size.
![](http://i49.photobucket.com/albums/f272/nevert00fast/HCDyno.jpg)
#52
Thats great result man
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
#55
Just the way the dyno ended the run
I guess I need to get back out there & keep building these heads.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
#58
NeverT00fast
did you have to flycut your pistons, what valve size are you using, what springs, are they out of the box or did you have them proted again or anything
great numbers man!!
great numbers man!!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#59
I'll let Jason chime in on the PTV clearance as I couldn't measure them.
I ran the heads out of the box with STOCK size LS2 valves, which is why these numbers are really impressive. Not milled, no additional porting, nothing. Jason installed the PRC dual gold springs on them and I just took the heads out of the box and threw them on the car. No flycutting, that was one of the main reason why I went with the heads.
