MS3 Cam Only: 424HP & 389TQ
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
My cam & bolt ons only car made 424HP & 389TQ (STD) nearly untuned! ![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
The car: 1998 Camaro SS, M6 car
The mods: Texas Speed Magic Stick (MS3) 237/242, .603"/.609" 113LSA
Fast 90mm Intake (De-ridged by Jonathan@Tick Performance)
Nick Williams 90mm Throttle Body
STOCK 1998 HEADS
Coated Pacesetter Headers into TSP True Duals
Powerbond Underdrive Pulley
!cats, !EGR, !AIR, !PCV
SLP lid, smooth bellows, descreened stock MAF
Car was dyno'd with 275/40/17 MT Drag Radials and a stock 10 bolt w/ 3.42s. It was previously tuned with the headers/cam, but now with the new stuff the driveability is terrible and it is leaning out badly in the mid-RPMs. I'll post the graph tonite.
The car is getting a Moser 9" with 4.11s and a tune as we speak - I'll post the updated numbers in a new thread.
STOCK 1998 HEADS
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by foff667
would you mind posting SAE as they are generally more accepted.
Thanks
Bill
Thanks
Bill
I was there, I made 438/401, and my SAE numbers were 430/393, so you can kinda figure it out from there. Joey, that's probably the highest TQ I have seen that cam make man, get that bad boy tuned, and let's see what it can put out
I'll check with them for the SAE numbers.
Ben - thanks! Your car was the king LS1 there that day. One of the best looking, too!![Icondrool](https://ls1tech.com/forums/images/smilies2/icondrool.gif)
Basically my only changes were the Fast90/90 setup, the pulley, and a few other misc things that likely wouldn't effect dyno numbers (tensioner, rod bolts, !pcv, etc). The last dyno was on street tires, as well. You can see the thread here.
I think the correction factor was about 2% going to SAE so that would put you at 415.5 rwhp and 381.2 rwtq. I am glad to see your numbers went up for what they were previously. I would get it tuned and redyno before the rear and see what kinda power you lose after the rear, that would be cool to know.
The air fuel was real damn lean in the mid range but at peak power got back inline to where it should be. I'd like to see what the timing values are set at, if they are like the rest I have seen with similar tunes, I am sure there is another 10 hp left in it.
Awesome #'s man & I agree with Ben it must be one of the highest or might be the highest rwtq i've seen from MS3 esp. untuned
As WS6FirebirdTA00 mentioned with SAE correction Factor would be 415.5 rwhp and 381.2 rwtq & that sounds damn good buddy
Keep us posted man !!
peace
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
peace
Great numbers. I would like to see someone do a car with cam and intake like yours and then put some cnc aftermarket heads on it with no other changes and see the power difference.
