TSP PRC "Terminator" Heads go 490 with MS3!!
#161
Originally Posted by Patrick G
Car probably weighs 3300 lbs with your 9" plus whatever you weigh.
Oh yeah, forgot about the 9". I Also have a steel driveshaft and sub frame connectors....
#162
It will definitly take away from those high numbers you have....you should really get some numbers with the new rear end and ds....
This makes the 490 claim inaccurate now...
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
-Chris
#163
Originally Posted by HartAttack
right on. what gears?
-Chris
-Chris
Not a "claim", the car made 490.... I have the dyno sheet and video to prove it. I'll dyno again within the next few months with the 9" and see what happens then.
#164
Im just curious to see what its actually putting down right now with the rear...cause they tend to take away a bit of power....
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Chris
#165
dont take it the wrong way, i saw your dyno graph, i know that you made that much power.
Im just curious to see what its actually putting down right now with the rear...cause they tend to take away a bit of power....![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
-Chris
-Chris
Not taken the wrong way
#166
Yeah the DA here blows. My best time on spray was 11.44@124 1.8 60'. I was pullin the same 60' on nitrous as I was on motor though?? No track prep at all probably had something to do with the that.
Best motor run was 12.21@112 1.8 60'
Which clutch are you using?
That thing is going to fly with good track prep and a better DA.
negative da's are coming up here.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#167
Originally Posted by Checkmate
How much spray on that pass?
negative da's are coming up here.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
150 shot....
#168
i can't wait to get dirty dirty in roswell! looks like the roswell boys ( well maybe just buffhomer) are gonna get gangbanged!! woohoo doggie( isn't that how they do it "down south")?
#169
Moderator
In my opinion and experience a car that dynos at 490rwhp and with an estimated race weight of 3500lbs (Car weight 3300+you at 200) should trap faster than 112 at 7300ft which corrects to ~124mph at sea level.
As a comparison my car with a race weight of 3400lbs traps ~122 at 2000ft which corrects to ~124 at sea level and I know my car does not make anywhere near 490rwhp.
Although I am sure that your car makes good power and your ¼ mile trap speed is strong it just does not match a car with 490rwhp.
John
#170
LS1 Tech Administrator
A 490rwhp vehicle weighing 3600 lbs should trap around 123 in the quarter at sea level. If the race weight is 3500 lbs, it should trap 124 mph in the quarter at sea level. Add 7300 DA to the equation and the mph will drop around 7-8 mph. That means 115mph at worst and 117mph at best.
With trap speeds of only 112mph NA in 7300 ft DA, this is only 119-120mph at sea level. Certainly strong, but it would suggest some missing ponies. We never did see the dyno graphs showing the SAE correction. Is it possible to post them up?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#171
LS1Tech Premium Sponsor
Well guys as a sponsor of this site & the person that dynoed the car I'm a little offended that you moderators are basically calling BS on Sean's dyno graph.
First thing in the morning I will be more than happy to post the graph again with SAE clearly on the side of the graph.
I'm really disappointed in you guys, you'd think moderators wouldn't be so biased towards their cylinder head of choice that they would attempt to discredit a vendor on this board. You both are basically hinting that the dyno sheets are completely false & that the results aren't accurate. How do you figure Sean's results are somehow that far off from the power your car makes Patrick? He's running a larger camshaft, and a cylinder head running a port developed by one of the leading LS based cylinder head specialist in the country.
This is Sean's first trip to the track with a rear end & a sticky tire. How about instead of attempting to discredit him & one of the leading shops on ls1tech you just give the kid a opportunity to practice & hone his driving skills.
Once again I'd like to offer up the opportunity for ANY heads cam stock bottom end car to race my heads cam stock bottom end car. I'll run the PRC cylinder heads against any heads cam stock bottom end car you want. No matter what the valve angle!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#173
91 octane is the best Alb. has I think!?!?!?
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
#174
LS1Tech Co-Founder
Dyno numbers and track numbers with a M6 can be two different animals.
I believe the dyno numbers, and they are impressive. The track results are a little weak but most of us get better over time (probably with the exception of me driving stick).
I'd have to be there watching this guy make passes to see what power is left on the table.
There would be a big difference say having Rodney (Smokino1ta) wheel that car and the the owner, Rodney has a ton of fast passes with a T56 under his belt.
Play ball but nicely.
ADMIN
ADMIN
#175
Moderator
Jason,
I hate that you took offense to my opinion and it was never my intention to question your integrity.
My opinion is based solely on the data in this long thread. If the heads were AFR, ETP, or TEA my opinion would be the same.
There is no question in my mind that when you dynoed the car it did put down the 490rwhp on your dyno. But the fact still remains that a 3500lb race weight car making 490rwhp should trap faster than what this one did.
Maybe the driver was short shifting; maybe the car weighs 3800lbs?
John
John
#176
LS1Tech Co-Founder
I'll write this one off as lack of racing experience or an improperly set up combo (suspension, gearing, etc...) for the track. A properly geared 6-speed with that power and weight would trap in the 123-124 mph range at sea level. But, it wouldn't run like that the first time out, without dialing the combo in.
#177
Take it from another 6spd racer that when my car is right and I am right, it runs strong for the weight and hp that I lay down. Now , when the trans was giving me problems then it was a different story. My trap speed goes down from 121 in good air to around 119 and that is still not being terrible at driving a stick ,just not on par with what I can do when it is right.
Give the boy some time and he may get the trap speed up with some driving improvement.
#178
Preach it Jason
Ill put my money on that PRC headed car over anything else
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#179
Jason, there you go getting all defensive again. I did not say that your product was sub-par, nor did I even hint that another product was better so RELAX. I merely pointed out that with several runs that night and the best mph being 112 leads me to believe that not all ponies were present the night he ran. Do I believe the car made 490 rwhp on your dyno? Yes. Whether it was STILL making that power at the track is what I was questioning.
Not posting up complete dyno sheets after repeated requests only adds to the confusion.
__________________
#180
weather and driving plays a HUGE factor. explanation:
car is a 02 Z28 with lid, catback, maf (330rwhp)
my first night out i got a cool night with low humidity.
best trap: 111
next year on a hotter, humid day, and not hitting my shifts as good.
best trap: 100
who's to say there weren't other variables? there is way too many other factors for people to be saying the car is great or a dud.
best trap: 111
best trap: 100
