GEN 1 385 Cu.In SBC
Old Jul 30, 2006 | 10:53 PM
Cali99SS's Avatar
Default GEN 1 385 Cu.In SBC
This is at the flywheel:
http://i5.photobucket.com/albums/y19.../finaldyno.jpg
http://i5.photobucket.com/albums/y19...nonumbers1.jpg
http://i5.photobucket.com/albums/y19...nonumbers2.jpg
http://s5.photobucket.com/albums/y19...nt=385dyno.flv
Old Jul 30, 2006 | 10:57 PM
gomer's Avatar
What's the combo on it?
Old Jul 30, 2006 | 11:00 PM
Cali99SS's Avatar
It is a 385Cu. In. SBC. 4 bolt main. Crower rods, custom cam (282/286 adv. dur. .712 lift, lifters, and valve springs. Eagle cast crank. Jesel shaft mount offset rockers (1.6:1). Dart iron eagle 230cc heads CNC'd by M2 Racing (333CFM@.800). Super Victor intake manifold (Port matched to Fel-pro 1209) Professional Products Harmonic balancer. MSD Pro Billet distributor, 8.5mm superconductor wires. Holley 950 HP carburetor.
Old Jul 31, 2006 | 06:38 AM
Patrick G's Avatar
LS1 Tech Administrator
Nice power, but the torque is a little soft. I would expect the torque to be in the 480-490 range on an engine dyno when optimized. Should haul *** though. Well done.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jul 31, 2006 | 05:41 PM
Big-DEN's Avatar
If its an auto numbers are awesome. If its a manual the TQ is a bit low. Fixing the TQ fixes the power proportionately.
Old Jul 31, 2006 | 07:44 PM
lilbuddy1587's Avatar
Reading is your friend
It's at the flywheel
Old Jul 31, 2006 | 07:53 PM
Big-DEN's Avatar
No disrespect, but the numbers are low. TQ for that motor should be close to
if not over 500ft-lb, ask Patrick if you don't want me saying that, and with that being the case, if it is something fixable - IE bringing the compression up, cam timing, ignition timing, port transition issues, your power will be well over 600HP but under 700HP, again, ask Patrick if you just don't want to hear it from me.
Old Jul 31, 2006 | 11:40 PM
Cali99SS's Avatar
I don't mind constructive criticism(sp?). I know the Compression ratio is low. that is intentional, street driver, 91 octane. Port velocity is probably low considering the size of the heads. 242cc intake. I will probably go EFI early next year and then Turbo(s) the year after that.
