How long does a typical dyno tune take?
Old Sep 6, 2006 | 12:34 AM
Azar's Avatar
LS1TECH Sponsor
Default How long does a typical dyno tune take?
Hey all,
My project car is nearing completion (kind of) and I'm probably going to need a good old fashioned tune. I was wondering, if there is a usual time that the tune takes.
My reason is that a local shop costs 450 for the tune, whereas another local shop is 150 an hour. Both deal pretty much exclusively with LS1's. So, yeah...just kinda wondering. Thanks!
Old Sep 6, 2006 | 02:46 AM
TV559's Avatar
A tuner that knows what there doing should not take more than a hour, But some shops take up to 4-5 hours to tune a car I dont why but they do.
Old Sep 6, 2006 | 02:47 AM
ringram's Avatar
Is that full timing map tune or just a WOT one in 1hr?
Old Sep 6, 2006 | 04:42 AM
EPP's Avatar
EPP
A tune that takes the time to do good part throttle tuning takes a lot longer. It is easy to get the full throttle tuning accomplished, the time consuming portion is the part throttle tuning. Three to four hours, sometimes longer can be expected. Bob
Old Sep 6, 2006 | 08:23 AM
Black02SS's Avatar
This is very untrue. I'd like to see a tuner get it all done properly in an hour. Key word is properly. Sure you can cut corners but the customer will ultimately be back to fix a problem.
Old Sep 6, 2006 | 08:32 AM
Slowhawk's Avatar
LS1Tech Sponsor
A tune can take 15 minute's to 8hr's depending on the car and if there are mechanical issue's with it.
A dyno only tune can take 5 minute's but it won't last long
Old Sep 6, 2006 | 08:46 AM
dynocar's Avatar
I find it hard to believe that a good tuner can do a proper, professional tune on a load control chassis dyno on any car, especially an auto trans H/C car in an hour. Doing optimum fuel/spark tuning for engine start, idle, part throttle, WOT, auto trans shift points and dealing with typical bugs takes a lot of time. I've seen good shops spend more then an hr just on idle with some of the after-market throttle body/cam/tight torque converter combos. One hour (?), it usually takes over 30 minutes to get the car strapped and all the equipment hook-ups on and off the dyno. One thing I've observed about tuners, the more they know, the longer they take.
Old Sep 7, 2006 | 05:53 AM
EPP's Avatar
EPP
Thumbs up
Well said! Bob
Old Sep 8, 2006 | 04:11 AM
ringram's Avatar
Good info. Has made me change my mind on how much time Ill book the dyno for. Lucky I have the road runner, so hopefully that will help reduce time on the dyno. I think Ill go for a half day for a start.
Old Sep 8, 2006 | 04:30 AM
Doc's Avatar
Doc
This is a very good point. If you assume the car does not have any "issues," and a straight WOT tune, ok an hour. Furthermore are we talking elapsed time or time billed? Is this a Wild cam that the customer wants it to drive like butter in all conditions? One heat cycle to get the dead cold start is at least 6 hours inbtwn sessions. The more experience a tuner has the less time it will take him to get into the ballpark.
Old Sep 9, 2006 | 04:55 PM
Tom@SpeedInc's Avatar
Considering a good tuner may put the computer in speed density, smooth the VE table then go back to running the MAF you get your $450 worth.
Old Sep 9, 2006 | 05:52 PM
Patrick G's Avatar
LS1 Tech Administrator
I've spent over a year's time trying to get perfection with my tune. I'm glad I'm not paying by the hour. This is where doing it yourself pays big dividends.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Sep 9, 2006 | 06:23 PM
AJay's Avatar
Can someone recommend a good tuner in the Pittsburgh area?
