how does DA affect dyno numbers?
Normal rule for DA is a 3% reduction for or every 1000 foot increase. Believe me, the calulations can get real tricky..different temperatures have different effects as the altitude increases etc..
I've used the "Engine Tuners Calculator" before..(Google) with pretty good success. Have had some hot summer days at Denver, Colorado where the DA was 9350. About a 22% loss of power.
If your orginal 450HP was uncorrected, then about 504HP.
Probably why most people like SAE corrections..evens the playing field.
Hope this helps..
Brian
HiTech Motorsport
I most dyno's will compensate for this so if you dyno in the summer and go back in the winter the results can be comparable.
The DA is Density Altitude and indicated in feet. If the DA was 0 then standards at that sea level are absolute. When the air is bad the altitude goes up and vice versa. It is a measure typically used for aircraft as the DA effects the fueling of the engine as less air is available the higher you go.
