431rwhp/386rwtq - TEA LT1 heads/custom TR cam
I can shift faster than you.
We just finished my girlfriend's car last week and were very pleased with the numbers it put out.
The plan was to do the heads/cam over the course of a weekend, but once the stock cam was removed, the front cam bearing showed a ton of wear. We pulled the motor and found nearly all the bearings in the motor were showing copper. I was pretty surprised given the relatively low miles (66k).
Anyways, here is the mod list:
Rebuilt LT1
- Stock pistons, rods, cranks
- Total Seal rings
- Clevite main bearings, King rod bearings, coated Durabond cam bearings
- ARP rod bolts
- Melling HV pump
- Canton pan
-Total Engine Airflow (TEA) ported stage 2 LT1 castings (2.00/1.56 Manley valves) ~ 11.0:1 compression ratio; heads flowed ~ 265/200 at peak on Thunder's bench
- Thunder Racing 234/248 .608/.576 110lsa (110ICL) hydraulic roller
- Crane 99893 valvesprings w/ Ti. retainers
- Comp 1.6 rockers (7/16" studs)
- GM guideplates
- FMS 7.350" pushrods
- Morel lifters
- FMS ported LT1 intake manifold
The car is a '95 Z28 6-speeed with Hooker longtubes w/ no cats, Hooker catback, CSI elec. water pump, AS&M 58mm TB, MSD 6A and coil, Dynapark opti, SVO 30lb inj, Racetronix fuel pump, LS1 alum. driveshaft, stock rear w/ 4:10s.
Final #s were: 431rwhp/386rwtq through full exhaust! Not bad for LT1 heads/intake!
Dyno graph: http://i120.photobucket.com/albums/o...yeatr/dyno.jpg
Needless to say, it is a night and day difference from her bolt-on setup! Huge thanks to everyone involved in getting Nat's car back up and running and Brian @ TEA for a killer set of heads!
Jason
Rebuilt LT1
- Total Seal rings
- ARP rod bolts
- Melling HV pump
- Canton pan
- GM guideplates
- Morel lifters
Jason
It was just a super budget rebuild and wasn't planned. We didn't want to dump a ton of money into this motor as we will be starting a 383 buildup this summer.
i did something very similar, but did not do heads, its easier to say "why didnt you do the bottom end" when really if you want to do that right its going to pretty much double your spenging.
Must be a great girlfriend
Originally Posted by Beast96Z
Nice job Jason. We had Tooley doing us some LT-4 heads, but they were "lost" during there move a while back. We ended up with Meaux doing us up a set. Sending you a PM on a tuning question.....
Did anyone happen to get a killer deal on some LT4 castings around Nov 2004?
Congrats on the power Jason, looks like you put together a killer combo
Thanks everyone, it is just nice to have the car back on the road!!
The LT1 pistons already have valve reliefs and the cam cleared just fine. We used a .026" thick gasket from Mr. Gasket.
Jason
Jason
LS1 Tech Administrator
Jason, you have the magic touch. Another fabulour combination of parts. Kudos to everyone involved!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
