Procharger/9psi/624hp,529tq
I just got done doing this build:
00 SS 6spd 3:42gears
Procharger D1 9# of boost
AFR 205
FAST 90/90
Stock bottom end
224/228 581/588 114+1
42# inj
The car put 624hp/529tq on our Dynojet, I know this thing has alittle more in it but we ran out of injectors. They maxed out around 6000rpm with an AF ratio of 11.4 and timing around 14*, so it still has some more room to go up.
AFR 205
FAST 90/90
Stock bottom end
42# inj
1 Post
Put some injectors larger then 42#'rs in her to see what she can do with adequate fueling. Good preliminary results. Final numbers should be sick....
Wow man...... great #s. With 42's and that H/C combo I'd be worried about fuel but apparently not according to the A/F ratios though. How long that bottom end lasts I'm really curious. I'll have my TEA TFS heads and 90/90 combo all together next week. A year of that setup (or less knowing me) and I'm going to be searching for boost
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
