Help me pick my next cam.
Old Jan 27, 2007 | 04:31 PM
NeverT00fast's Avatar
Default Help me pick my next cam.
I recently changed the heads on my car to Trickflow 215cc and added a Fast 90/90 setup.
Here's the chart.
The full mod list on the car, car is a 03 Z06.
Trickflow 215cc heads milled to 59cc, stock GM MLS gaskets.
TSP MS3, 236/242 603/609 113.
Ported Fast 90/LS2 TB unported.
ASP UD pulley.
Kooks 1 3/4 LTs, no cats. Stock titanium exhaust.
Halltech Stinger.
FAST 36lb injectors.
Cartek Clutch.
DTE 3.73 rear.
NX 100shot wet.
The car is making decent power, but not as much as the other TFS H/C combos. But Cartek is known for getting lower dyno numbers than other shops. My main issue right now is not really with the peak power, but with the power curve especially the torque curve. The car is hitting peak torque at 5.5k which is way too late, and the HP never really peaks. I'm not sure if it's because there's not enough timing or what. I have an idea of what cam I should be putting in there, but I want to see what you guys think.
Basically, I want the peak HP to be at least 480rwhp and the peak torque around 420rwtq. But I wan to make the peak torque at about 4500rpm and the peak HP at around 6500.(I shift at 6800) I'll be changing the cam only, so I can't go with a thinner gasket to get more CR. AND I want better driveability on the low end. Right now the car is so sluggish under 2k rpm, and it keeps on wanting to die out at when I clutch in.
Vengenace's 500rwhp combo is with a cam that has even more duration than the MS3. I think it's like 238/243 .602/.598 113+2. However, that cam does get the power in earlier, hitting peak torque at around 4600rpm.
ECS's 500rwhp combo has a cam that's around the high 230s in duration, probably 236/236. Right under .600 on lifts and on a 114 +?. The dyno chart I saw on this cam has peak torque at around 4800 rpm, not too bad either.
So, what cam specs do you guys think I should be going with?
Old Jan 27, 2007 | 06:45 PM
bad95killer's Avatar
Brad02Z06 Changed his Camshaft from MS3 to Vengence Custom Camshaft besides he has 1 7/8 kooks longtubes which effects on his mid range anyway here's his Graph hosting by me
His Thread https://ls1tech.com/forums/showthrea...0&page=1&pp=10
I woudn't really hesitate to call Ron@Vengenceracing to give ya the right directions buddy
Btw really impressive numbers so far man
peace
Old Jan 27, 2007 | 07:05 PM
Yah, his cam actually has more duration. I wonder if it'll have better street manners than the MS3...
Old Jan 27, 2007 | 07:57 PM
Originally Posted by Brad02Z06
I don't have a MS3 anymore.. I got a Vengeance custom cam.. Driveability is much better than before!!!
Believe me man it's all about tune
peace
Old Jan 28, 2007 | 09:36 PM
I know it's mostly in the tune, but my car is tuned by Cartek so it's not like the car is tuned by some Joe Schmoe. I don't know, it's a little frustrating that all these 500rwhp H/C combo cars running similar sized cam have pretty good driveability when I still have the stupid idle hunting issue.
Old Jan 28, 2007 | 09:44 PM
Patrick G's Avatar
LS1 Tech Administrator
It's not all in the tune...it's pretty obvious that your cam is mis-matched for your combo. Too late of an intake valve closing point, too wide of LSA and more than likely too low of DCR. Look at all the recent big torque dynos...they all seem to make their cubic inch displacement in torque by 3000 rpm, they carry a big peak torque number and also make an outstanding peak hp number. It's all about area under the curve. Get the right cam in there and you'd be right up there with the best of them.
Narrow the LSA, close the intake valve a little earlier, make sure overlap is either centered over TDC or biased to the intake side of TDC, and try to maximize dynamic compression around the fuel you're using.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 28, 2007 | 10:06 PM
This is what my DCR look like right now,
I'm thinking about going with something like a 232/236 595/602 112+2.
That'll look like this,
Old Jan 29, 2007 | 01:57 AM
Slowhawk's Avatar
LS1Tech Sponsor
I'll bet it's installed at 113 degree's.Moving it to 108 would probly make a huge difference.
Old Jan 29, 2007 | 07:09 AM
Patrick G's Avatar
I agree. Unless you installed it with a degree wheel and know for sure, you have classic signs of a cam being in at a retarded intake centerline. Advance the cam to 108ICL or choose a new cam based on the parameters I laid out above. A smaller cam on a 112LSA will help bring back some bottom end, but not as much as a cam with a narrower LSA and proper valve events. Don't be afraid to go 110LSA.
__________________
Old Jan 29, 2007 | 07:32 AM
The cam was installed dot to dot as far as I know, so you're saying that they might've installed it incorrectly and retarded the timing? If I going to tear the car down to where I can advance the cam, I might as well throw a new cam in there. What would be the difference between going with a 112+2 and a 110 LSA?
Cartek is telling me to go with something like a 232/234 cam but on a 114LSA, they're saying that the tight LSA is causing more overlap and with the larger valves now the car have is causing the surging at 1500rpm and the idle dip.
Old Jan 29, 2007 | 08:29 AM
Patrick G's Avatar
Dot to dot is no guarantee that the cam was installed at the proper intake centerline. Variances in cam grinding, chain stretch, and sprocket orientation can all add up. Like I said, look at all the stock CID setups that are making over 425 tq. I highly doubt you will see many or ANY running a 114LSA. Do some more searching and see what setups people are running for maximum area under the curve. You will see lots of consistencies.
__________________
Old Jan 29, 2007 | 08:47 AM
With a 110LSA, is it possible to have good driveability without going to SD tune? Like no surging under 1500rpm and rpm not dipping when clutching in?
Old Jan 29, 2007 | 08:52 AM
JRracing's Avatar
My first cam was on a 110lsa but kinda small duration and had lots of TQ. It drove well also.
My second cam was like a x3 on a 114lsa. It had low power under 4K rpms. And it was tough to get it to idle well. My tuner had a issue with this.
Now my new one is on a 110 and I'm sure it will do well also.
Theres my .02.
Old Jan 29, 2007 | 09:04 AM
Patrick G's Avatar
If you have the right tuner, definitely! But you also shouldn't be apprehensive about a SD tune. Speed Density opens up tuning windows that aren't possible with a MAF. But to answer your question, yes, you can easily run 110LSA with a MAF if your tuner knows what they're doing.
__________________
Old Jan 29, 2007 | 05:56 PM
Thats exactly what i meant by a good tune Pat cause i was referring to A whole diff. Custom Camshaft On tighter LSA
peace
Old Jan 30, 2007 | 07:01 AM
What about this TSP cam, 232/234 .643/.598 111.
Old Jan 30, 2007 | 11:34 AM
lilbuddy1587's Avatar
232/238 .643 .605 111+2 LSA
LSK 2128/ XE-R 3729
Using all your same info, I get 11.43 SCR and 8.73 DCR
Old Jan 30, 2007 | 12:32 PM
How much power would I loose if I go with the XER lobe on each side?
Old Jan 30, 2007 | 03:05 PM
What's the difference between these lsa if all other specs of the cams are the same?
110
112+2
112 lsa installed at 2 degrees advance.
Old Jan 30, 2007 | 07:12 PM
LSK 2128/ XE-R 3729
Is that what ya have in your car now lilbuddy ?!
peace
