Cam only Ls1 440rwhp (Vengeance + Harris Tune)
Old 03-10-2007, 07:58 PM
347fairless's Avatar
Default Cam only Ls1 440rwhp (Vengeance + Harris Tune)
Lets just say this cam kicks some ***.
Vengeance Vindicator Cam
Specs: 240/244 608/598 112
Vehicle Mods
2002 Ws6
SLP Lid (K&N)
SLP FFRA
Gran MAS
BW ported TB
ASP Pulley
SSauto 1 3/4 headers
QTP Ypipe
Flowmaster CB
4.10 gear (8.8 rear)
42lb inj
Please excuse the shitty graph. I will post a high res color copy tomorrow.
Only items added were the injectors and Harris Tune. I am floored to say the least.
All numbers SAE corrected. Uncorrected were 459/430. I have this graph as well. A/F was about 12.8 near peak. 42 inj saw about 68% duty cycle. Timing was 29. Idle 900rpm. Again, I will post a MUCH better graph tomorrow.
Yes, it hunts for idle when cold, about 20 seconds unassisted.
Vindicator Idle Video
Attached Thumbnails Cam only Ls1 440rwhp (Vengeance + Harris Tune)-camonly.jpg
Old 03-10-2007, 08:02 PM
JDPZ28's Avatar
WOW! very impressive. I'd like to see what it would have been with a Fast 90/90, and then some good heads.
Old 03-10-2007, 08:15 PM
Sluggish's Avatar
that's badass......nice smooth powerband
Old 03-10-2007, 08:44 PM
I will be getting some track times on St Patty's day at Cecil with video. Got a grudge race against my boys bolt-on 2.76 pulley cobra.
Old 03-10-2007, 08:49 PM
KAOS's Avatar
that tq is nasty, post up some track numbers asap
Old 03-10-2007, 08:51 PM
eric01ss's Avatar
u should get some truduals and a fast 90/90 and see where the power goes!!
Old 03-10-2007, 08:57 PM
speed_demon24's Avatar
All the dyno #'s I've seen from there were higher than normal, but good #'s I guess. A cutout's worth 20-30rwhp over the flowmaster, and a fast 90/90's worth what 10rwhp? That would put you at 470-480rwhp cam only if you want to believe those #'s.
Old 03-10-2007, 09:09 PM
That didn't take long...
Old 03-10-2007, 09:10 PM
JRracing's Avatar
HAHA,I'm getting married that day! Good luck. I hope you kick his ***!
Major props to Vengence. Nice work!
Old 03-10-2007, 09:29 PM
Cmon even you have to know those #'s are hard to believe, expecially through a flowmaster, one of my friends gained 25rwhp with a cutout and he only put down 375rwhp. Now if you go to the track and trap 122+ I'll shut my mouth.
Old 03-10-2007, 09:32 PM
Considering what the car trapped before the cam, you probably will be shutting up.
Old 03-10-2007, 09:34 PM
Actually open your eyes, and check out the other Vengeance cm only threads on some of the other forums, that haven't used this dyno. Numbers are not far off at all.
As for the flowmaster, this muffler has a delta series big block part number, not sure if that is the same or different then what Flowmaster intended to use on the kit.
Thirdly, post some examples of high numbers from Harris, and back up your claims.
I searched the dyno forum for Harris. 12 threads come up, only one (bolt-on A4 - 360rwhp) seemed off. All the others were spot on.
Old 03-10-2007, 09:46 PM
registered user
ScreaminRedZ's Avatar
Those are some SICK numbers! Definitely want to see how she does at the track.
Old 03-10-2007, 09:47 PM
Mssingkid's Avatar
Healthy sized cam there... Very nice numbers!
AlexLS6's Avatar
Vehicle Mods
2002 Ws6
SLP Lid (K&N)
SLP FFRA
Gran MAS
BW ported TB
ASP Pulley
QTP Ypipe
Flowmaster CB
42lb inj
All numbers SAE corrected. Uncorrected were 459/430. I have this graph as well. A/F was about 12.8 near peak. 42 inj saw about 68% duty cycle. Timing was 29. Again, I will post a MUCH better graph tomorrow.
WOW!!! Very nice number! Do you need to flycut your piston with that cam ? Now It's time to put some heads and a 90/90 set up...
Old 03-10-2007, 09:58 PM
No flycutting here!
I refuse to pay for a 90/90. Going the ported Typhoon/90 route when their LS1/LS2 intake comes out with the bigger TB opening.
Old 03-10-2007, 10:06 PM
Irocss85's Avatar
yeah that torque curve looks AWESOME. cant wait to see the ET's. you need some good tires though. you should be in the 1.5's with a 4.10 gear, t56, that kind of power. but it'll be tough to get it to hook with those tires. but judging by your old mods/ETs looks like your doin pretty good job of driving that car. Im very curious how that 8.8 rear will hold up for you. do you have any pics of that torque arm setup I can see? if so pm me some.
Old 03-10-2007, 10:08 PM
Thanks. If you search my name in the driveline forum my post should come right up with all kinds of pics of the torque arm mount. Its solid.
Old 03-10-2007, 10:14 PM
2xLS1's Avatar
What kind of dyno is that on? That graph doesn't look like Winpep Dynojet.
Old 03-10-2007, 10:24 PM
Not sure. Maybe HSW can chime in if its not a dynojet.
Quick Reply: Cam only Ls1 440rwhp (Vengeance + Harris Tune)
