Is dyno tuning worth the money?
If you want to pay a little more now some tuning shops offer free updates after you pay ~400+ for your initial tune.
a dyno I saw only used a small pipe that he put on one tip of the exhaust I think he`s using the stock O2 sensors...is that wide band tuning or he has to put one or two wide band sensors there?
Knock could be caused by a few different things. A lean AFR is one reason. Adding more fuel does take car of this. I use HPTuners and a Mustang dyno, so your tuner not able to tell you how much timing you're seeing at WOT bothers me. I scan, log, and save every pull, total timing advance is one of the things I"m always looking at during the pull, plus it's in the tuning file, he should have just been able to look it up under one of timing tables.
I wouldn't be messing around with a MAF translator if I didn't know what my AFR is. Once I know what it is, then you can start figuring that a 2% increase to the translator will add 2% fuel. Example 13.1:1 AFR plus 2% through the translator should result in a new AFR of 12.8:1, but if you don't know what your AFR is then how do you know how much fuel to add or take away?
I think my tuner kinda knew what he was doing but was only willing to go so far. Like he expected better results quicker and when they werent coming he converted to owell its better than when I started so thats good enough. It wasnt a challange to him-it was just a job. That might be ok if it was a couple hundred but I really expected more for $600.
Basicly, with a dyno, you are seeing change. You will add/subtract timing/fuel to make the most power. Dyno numbers as a comparion is a bad idea.
Some cars benefit more from a tune than others, it all depends on the car. Also ls2 cars are under-tuned from the factory, so they benefit even MORe from a tune.
It's worth it after a round of mods, because you only have to pay the full price once. I would get all the boltons, and then a tune, and you'd be sitting pretty.
I'm sure he did, I just found it weird that he didn't tell you, I always get asked how much timing is in a car after I get done tuning it. Oh well.....
