TEA L92 headed 416ci Z06 going to the dyno tuning tomorrow 10am
C5 Z06.. engine specs Total engine Airflow ported L92 heads with TEA ported intake , 90mm shaner ported LS2 TB, 12.1 Comp, 416 ci, 60lb Motron injectors 1'' 7/8 headers, no cats, custom comp cam 250's/ 260's duration a 110 LSA, .650 lift.... Take your guess's now.. I'll post up a dyno graph later tomorrow
LS1 Tech Administrator
The combo sounds like all the bases have been covered. A cathedral port setup should make in the 550/510 range (as stated above) so if the L92 does not hit those numbers, it will be disappointing. If it exceeds that, then it was money well spent.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Originally Posted by ls2 bait
i bet it looks a lot like this........
110 LSA scares me, and I'm fearless
Seriously though, I think the narrow LSA cams with big intake valves are a bad deal. It seems it would make more torque, but run out of breath sooner, so if it peaks sooner then the other graph, you will know what happened. I hope I'm wrong.
Originally Posted by SideStep
Well... it is now later "tomorrow", what were the results???
Originally Posted by CougarL92
We did'nt get too far into the dyno run's / tuning, Due to a very bad exhaust leak coming from the drivers side header around the slip on collecters, It was causing the left bank to drop 50 % more fuel than the right side.. We stopped after the 3rd pull at 533 RWHP SAE. I will be getting the leak fixed today and hopefully getting back on the dyno before friday and post up a new dyno graph.
how could a post 02 sensor exhaust leak mess with fueling at all??? 50% more fuel??? thats alot more fuel dude..... lol
if it was getting tuned they could have just left the car in open loop and finished the tune, plus at WOT o2s arent working so you could have reset the trims and been ok. Either way you werent seeing 50% more fuel, max on that bank during WOT would be +25%.
Sounds like someone is just trying to make some more dyno money
the only thing i can think of is that they are tuning with a wideband in the tail pipe... if they are then the car can suck in air where the exhaust leak is at and give false readings to the wideband sensor.... highly doubtful... but could happen
how exactly they know the one side has more fuel than the other if they are tuning with a wideband is beyond me... maybe they are running two widebands, one in each side just after the collectors??
