Final #s MS3/AFR 205s - A4
Here are my original and final numbers.
Stock 1998 Z28 A4 - Totally Stock w/30k on the motor.
285wrph / 306 rwtq - 3550lbs.
13.6 @ 103 w/2.1x sixty warm/humid on Goodyears
1998 z28 A4 - Modded @ 95K on motor in june
AFR205s milled 63ccs
MS3 Cam w/ Dual Springs
MTI Lid
Fast 90/ PTM 90
Hooker 1 3/4 Headers/ Custom 3" X / Custom Mufflers Dumped
Underdrive Pulley
38lb injectors / Holley 255 Fuel pump
SS4000 Converter
Stage IIII 4L60E
Stock 10 botl w/3:73s
BMR Boxed Control Arms - Other Suspension stock
17" Roh Snypers on all four Corners
429.55 rwhp / 388.5 rwtq - locked
11.67 @ 116 w/ 1.67 sixty - Warm/Humid w/17 Rohs upfront/EtStreets in back
Converter Swap numbers
3500 stall - 420 rwph / 367 unlocked 99degrees/34% humidity
3500 stall time = 12.3 @ 116 w/ 2.1sixty in 55*s weather on Nittos
4000 stall - 386 rwph / 334 unlocked 95degrees/89% humidity
4000 stall time = 11.67 @ 116 w/1.67 sixty @ 85*s/89%humidity on ETstreets
Same track and dyno @ 1100+ above sea level.
All times and dynos are on 91 octane gas.
Wish the trap was higher, gonna go back in cooler weather
Car is 3650 lbs. no skinnies w/swaybar, stock trq arm, stock shocks
MTI Lid
Fast 90/ PTM 90
Underdrive Pulley
SS4000 Converter
Stage IIII 4L60E
[QUOTE=Mazzenger]John563 - bottom end is bone stock also.
Its pretty fun to drive. Cant wait to feel it in the cooler weather.[/QUOTE
thanks for the info.It makes feel better.Im thinking of going with a slightly bigger cam myself.I have TSP stage 2.5 5.3 l heads, ported fast 90/90,TR224/112 cam(A4) and put down 417rwhp 407rwt.I want more rwhp,but dont want top give up too much tourque.How does the MS3 feel down low?
thanks
john
thanks
john
When I first put it in, the car had 3.23 gears and 3500 stall.
Felt sluggish down low.
I added 3.73s. Thats all it took. Felt great all over. Was a totally different car.
Tons down low and even more up top. The 4000 stall made it even better. But driveablity is a bit worse. Oh well.
What do you run at the track? 417/407 are great numbers.
I have not ran it yet with the heads/cam.I just got the heads in. Did the 4000 stall make the driveability worse or you talking about having a big cam making driveability rough.I have a 3500 stall,and I'm thinking of getting 3:73 gears for a bigger cam But dont want to get such a big stall.I was thinking of putting in a T2 or T3.You ever thought about getting your fast ported?When i was just cammed with an ls6 intake i put down 350rwhp and then added the heads and ported fast and got 417rwhp.
