How much hp can i get out of my 383 ls1
Hey im new to this hole thing and i am building a 383 ls1. It has dart 225 heads, ls6 intake, 90mm tb, a 238- 242 at 114 at 605-615 lift cam, kooks 1 7/8 headers, and i was hoping it would make good power n/a. If any one would have any idea i would appreciate it. thanks Darrin
The darts make power too. its just the right combo to work together though. I have a freind with a 383 with the dart 225 heads that have been massaged for a little more flow and with 11.3 / 1 compression and a 239/243 cam close to yours laid down 425 hp through a unlocked 4400 stall in a th350. car runs 10.9's at the track and traps 124 mph in sea level DA
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I don't think people are ever going to agree on whether a 225 head will make more power than a 215 or 205 head on a 3.9 bore. I had ETP 225s and switched to TFS 215s. I did not pick up any power over my 346 setup despite adding a bigger cam. My car is running 10.2s @ 130 on the motor at 3320 lbs in positive DA. However, it probably would have done that with my 346 setup if I had ever had the chance to make a pass. We'll never know though. For now I'm just trying to figure out why the extra displacement didn't give me any more power...anywhere. In fact, with the same cam I actually lost 15 to 20 rwhp...everywhere.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Ic well i can just try this set up u can always change things along the way, i am also going to run a 150-200 shot is there a right compression ratio to do that at its not like ill use it all the time just when i need it or go to the drag stip
