2011 mustang dyno and run numbers
first run: 13.2 @ 110 stock
2nd run 12.8 @ 111 stock
next run 12.49 @ 112 stock with dr's
stock dyno: 368rwhp / 352 rwtq
modded dyno 405rwhp / 375 rwtq: off road X, cat back, drop in filter, tune
today's run... 12.04 @ 117mph drag radials blown up clutch. same setup as yeesterday. only a few bolt ons and tune.
i am about 95 percent confident the 395 rwhp test car had non restrictive cats, or none at all. the cat pipe is a straw. removing it is most of the new performance. the tune is very little IMO. it seems ford's preproduction had an optimized exhaust. the actual production cars have the crappy version. ford only wanted 412hp, so the exhaust keeps it there.
found the cam specs. intake: 260 advertised .473" lift) / exhaust: 263 advertised"---.432 lift)
for reference the usual duration runs from 195 - 205 @ .050" for 4.6 dohc.
had to edit. actual @ .050 arent published. but, the frpp high lift cams that this motor started with have a few degrees less advertised duration.
frpp cams: intake duration 258°, exhaust duration 254°, 109° center line. frpp cams operate to 7000 rpms.
fr500 racing cams are:
FR500 (M-6550-T46)
intake: 212 deg @.050 /.472 lift (measured duration)
exhaust: 208 deg @.050 /.472 lift (measured duration)
109 LCs
those cams are good for 7200 rpm with fr500 intake.470 rwhp is the max so far with fr500's.
FR500 (M-6550-T46)
109 LCs
