Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
CAM only F-body to take out a C6Z06!
Old 12-11-2008, 04:56 PM
Elcaballoloco's Avatar
What do you guys think it would take to get some 125-128ish traps out of a F-body? T-56 or auto? I'd like some opinions on this.
What about a c6z? 125-128 is easy money for a stock c6z right?
Old 12-11-2008, 05:01 PM
chrs1313's Avatar
Originally Posted by XtraCajunSS
With a properly set up heads, cam, torque conv and chassis combo, it is more than do-able.
We have more than one cam only customer with bolt-ons, converter and gears running low 11's on nittos in a 3300-3500lb F-bodies. We also have more than a few cam only GTOs running 11.00 to 11.20's in the 3500-3800lb range...
The main point is, these are all well thought out, sorted out combinations. With the right planning and execution, its not all that difficult.
Thanks,
Shane
i would give the zo6 a lane
Old 12-11-2008, 05:04 PM
pitbull14218's Avatar
Nice alot of response's i like that, now say from a roll is there away N/A not too crazy to beat one?
Old 12-11-2008, 06:05 PM
Dave 96TA's Avatar
Originally Posted by Hardtop
You're dead meat if you race from a roll. From a dig it's possible. One other thing, if you do race from a dig you better not run much more than 1/4 of a mile or the Z06 will come around you on the other end.
Probably right.
Old 12-11-2008, 07:58 PM
danger ds's Avatar
You have a better chance from a dig on the street then from a roll. Not saying you couldn't beat it from a roll but even that race would have to be set from 1st gear to about 130mph, anything more than that and the Z could over take you in the top end because of the type of gears the f body would have.
All of that said if the F body is a 6 speed, lid, ported fast 90mm intake, race headers, cut out, MS4, Fly cut pistons with milled trick flow heads to yield 11.1 compression , 4.10 gearing, underdrive pulley, electric water pump, drag light wheels with a 325 50 15 mickey drag radial tire, I would put my money on the F body.
Old 12-11-2008, 10:14 PM
Lt1Porsche's Avatar
I think the main variable that needs to be taken into consideration is the fact that not everyone is a pro driver. Take your run of the mill driver and it will not be that hard. I have driven a Z06 and its not an easy one to drive at WOT. From a dig I personally dont think it will be that hard. You just need a decent cam and be able to hook. I beat 2 Z06's at the track with my mods and a 100 shot. Stock rear and no stall. Just on a set of nittos. The best he could pull was a mid 12. Not everyone can pull 11's in their Z.
Old 12-12-2008, 12:50 PM
00_Z-28's Avatar
To the OP whats the deal hear? Your talking about spending a LOT of $$$ is this a grudge race or what? Sorry just curious..... As for if you can take the Z06 I don't know most people on here know much more that I do ,but I would think that with a carefully set plan and parts that work with each other it could be done. H/C, gears, tires, and take care of the airflow on both ends and you could be making sick power. I'd pull the motor and start over from bare block. Get everything forged so you can spray big. Or like others have said go LSX.
Old 12-12-2008, 03:33 PM
MattysTA's Avatar
not a chance,this guy i know with a non z06 c6 goes 11.94 stock...
Old 12-12-2008, 03:41 PM
camscam02's Avatar
id take 95% of the stock ones from a dig cam only... not many can put those in the 10's stock or even with boltons.
from a roll it would be a guaranteed lose unless the driver sucked *****.
Old 12-12-2008, 03:55 PM
Grimes's Avatar
Honestly, the amount of money it will cost would be a nice down payment on a used C6Z06
Old 12-12-2008, 04:18 PM
camscam02's Avatar
less than 10k?
Old 12-12-2008, 04:25 PM
  #32
ZMONSTER!'s Avatar
Well that would be just motor mods, then you have to take into account the price of a 9 inch/drive shaft/clutch/suspension and tires
Old 12-12-2008, 04:44 PM
  #33
IFRYRCE's Avatar
I had a ridiculously long post typed up, but what it comes down to is that most people can't drive. I see C6Zs run 12s and 13s all day long at the track, embarassing anyone with an LS motor. Street/roll racing takes a lot of that away, but either way, a good driver in a lightly modded (mild H/C) F body powershifting like a proper American will take a rich ***** in a Z any day of the week. Its when you get someone like Ranger on the 'Vette forums driving against you that you've got a problem.
I've driven 3 C6Zs. Considering some of the stuff I've taken in them, if an F body rolled up against me on the street, he better be putting down AT LEAST 500 at the wheels if he wants a snowball's chance in hell of beating me, dig or roll.
Old 12-12-2008, 05:07 PM
  #34
bigfatls6's Avatar
Most of the c6zo6s I hav eseen with a desent driver run mid to high 11s in street trim on street tires. So a descent cam / bolt on fbody on nittos with a stall should be able to get it done. To those who say a heads and cam car can't get it need to look back into you combination. I had a regular set of 99 ls1 heads ported by patriot and a tqv3 with bolt ons and a 3800 converter and ran 11.50s on regular summitumo street tires.
Old 12-12-2008, 06:15 PM
  #35
darrensls1's Avatar
Originally Posted by krazy4
Gonna take a logical guess and say that the camaro would trap around 115-120mph and the vette will trap 120-130mph.
That would mean an absolute raping on the street.
The C6 Z06 is more along the lines of 122-125 mph in stock trim. A big cam in a M6 with all bolt ons can trap 119-122. It would be a close race with the Z06 having the advantage.
You need to go with a good cam only setup and then add a 150 shot for just those special occasions. Then it's by by Z06. At least when the bottle is full
Old 12-12-2008, 07:07 PM
  #36
RedDemonLsX's Avatar
Its definitly doable,i beat one by a half a car from a roll not to long ago and im an auto with a PT4000..It surprized the **** out of me,i thought i would go down because of all the "Talk" on the intraweb about it being...Unbeatable..lol
Old 12-12-2008, 09:07 PM
  #37
twin74s's Avatar
I raced one from a 50 roll in my nova on power tour this year. From 50 to about 130 he was bout a half a car back. My car is a tad lighter than a fbody but not as aerodynamic either. But he came around me pretty good up top. Like many others have said a GOOD working setup could easily do it. If your going from a dig your car better work... Make him catch you cause if hes already out in front your in trouble.
Old 12-12-2008, 11:12 PM
  #38
Formerly darynC-10/23/10
Daryn's Avatar
in the 1/4 its very do-able, but up there in the high speeds the z06 has a incredible weight-power-aerodynamics ratio,
Old 12-13-2008, 12:27 AM
  #39
Coppertop8705's Avatar
with times like these it'll be hard to beat!!
but i do think its doable.
how about instead of cam only, heads only car. i've seen a ls1 gto make some maaaaaassssive numbers with some AI heads
Old 12-13-2008, 01:37 AM
  #40
Grn4fbody's Avatar
Anything possible, even those the C6 Z06 is a beast...there could be such a thing as driver error.
Quick Reply: CAM only F-body to take out a C6Z06!
