guess my rwhp ? mods inside
Hi ,my car is 2001 WS.6 M6 , at few days i'll buy walbro 255 fuel pump direct in tank from speedINC , my mods below :
1- MS4 112 / patriot extreme springs 660 lift / comp pushrods stock length
2- hokker long super comp , y-pipe , SLP Loud mouth cat-back
3- Fast 90 with 90 t/b
4- dynotune wet shoot 175HP wet
5- 4.10 gears
6- stock 241 heads / GM MLS gasket .057
7- Diamond Flat top with -2cc valves reliefs , stock rods with ARP high performance rods bolts
8-front tires 16/50/245 , rear Mickey Thompson ET Street, 26 x 11.5 x 16
9- Spec clutch 3 , Mcleod Master cylinder
i talked to Bryan @ speedINC he recommend me to run with fast injectors 36lbs and walbro fuel pump , i'll buy the fuel pump but i can't buy the injectors because they are expensive , there will be problems if i installed fuel pump without injectors ? how much u guess guys my car will pull in the dyno without nitrous and with nitrous ?
thanks, Mohammed.
5- 4.10 gears
thanks, Mohammed.
guys please help me i spent a lot of $$$$$ , i don't have enough money to spend now , so please explain i have some question i hope to be answered
1- can i tune my car with 175 wet with stock injectors and stock fuel pump ?
2- can i tune my car with 175 wet with aftermarket fuel pump and stock injectors ?
3- can i tune my car with 175 wet with stock fuel pump and aftermarket injectors ?
