Dynojet Dyno number with these mods?
Well I decided I'd rather not use the Meth kit just to keep everything simple and get up and go worthy rather than having to measure out and fill before i go lol. With the mods in my sig - what power do you think i'd be making? I am hoping to run about 10psi maybe 11.
The hot side seems to be a .81, 3 inch piping to the turbo.
I know these questions are kinda stupid but its nice to see what ppl expect.
Do you do 100% meth with yours? Or do you do a mix? And my tank seemed pretty small - it is just a stage 1 snow performance kit..
Did you mean that target is good without the meth?
It should make your target plus some on 10psi.
i dont think many people are posting cause this question is asked all the time. Most of the threads that get good response are ones that deal with issues or finding that help everyone out. guessing hp numbers is a waste of time. my 0.02
thanks a lot STS......
The tuner is saying don't do it because what if I run out and don't know, etc.. I think im going to just tune it as is, and then throw a FMIC later on when it gets warmer out. Heat wrap the crap outta the cold side where it goes by the ypipe/headers
That is so true we logged my buddy ta intake temps where 80 degrees and after the burnout and run it was close to 200 degrees. STS with no intercooler and it was 70 degrees out that night. But after the intercooler and meth he pick up 100 hp go figure My meth last me a month or so and I use a 75% meth and 25% water.
Look at what Frost said in post #3. Meth will last awhile. Your not going to be in boost all the time so it will not run out that fast. I know some meth kits have adjustments on them where you can set it to come on at a certain boost level. No meth at 5psi and under and then meth above 5psi.
Don't run try it as-is, you will be paying more to go back and re-do (and re-tune).
