Do you think I can hit 11's on my street tires?
Any dyno numbers? It's gonna be tough on those street tires with the kind of power you should be putting down on that setup. I hate to go pessimistic on you but I don't see it happening unless those are some godly Patriots and you can drive your *** off (and my experience with Patriots is that there are no such thing as "godly Patriots"). Good luck, though, and I hope you nail the 11-second pass!
Sounds like you need to work on that launch. A 2.0 60' with a 108-109 trap speed should hit bottom 13s without issue and unless they are totally shot, a 2.0 60' is fairly common on street tires with a little seat time. There are many people out there hitting 1.9s on street tires from time to time.
ET Street Radials or ET Streets? The regular ET Streets are bias-plies and you probably won't want to run those as your everyday tires, but the ET Street Radials are kickass. They don't last as long as Nittos but they hook a thousand times better. As far as stickiness goes, street tires < Nittos < ET Street Radials. As far as tread life goes, street tires > Nittos > ET Street Radials. Keep in mind that if you're running the stock 10-bolt, you're probably going to kill it on Nittos eventually and you almost certainly will quickly on the ET Street Radials.
Administrator
Yea ive tried everything except drag radials or slicks. I usually cut a 2.3-2.5 60ft just because no matter what I do when I go off the line. Even if I just roll out like im pulling out of a parking spot, as soon as I floor it the whole 1st gear just spins. Idk what else to do ahah
Thanks Unit, I'm for sure going to take your advice. You might not be a bad guy after all. I intended on going around the wet box the whole time. I was out today practicing some launch's on a back road and feel I've got a good idea what to do so... My old man told me to try and leave out of 2 but on the street it just didn't pull hard enough.
Thanks for the ideas guys, I'll keep you posted!
I actually did this in a street race one time with two 250lb guys in my back seats so I could hook up on my bald 17" Nittos. It was against a M6 02 cammed SS Camaro. The Camaro made 40xrwhp. I was in my Procharged Cobra with 4.30 gears and I still beat him. My clutch however did not like that idea AT ALL.
