Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
What Will My Car Run In A 1/8th?
Old 10-03-2009, 04:12 PM
19BLACKBIRD99's Avatar
Default What Will My Car Run In A 1/8th?
I am going tonight to a local track and it is a 1/8th and I was wanting to know what I would be close to running?
Old 10-03-2009, 04:40 PM
Tech Apprentice
Stopsign32v's Avatar
mid to low 13's?
Old 10-03-2009, 10:37 PM
speedshifterNC's Avatar
Im guessing around an 8.5 or 8.4...and what he said in the 1/4 ^
Old 10-03-2009, 10:52 PM
01z
01z's Avatar
8's..
Old 10-04-2009, 11:12 AM
Tech Apprentice
Oh I didn't see you were talking about 1/8th. Yea, somewhere in the 8's. I'd say 8.6 if the track is average. (most 1/8th miles I've been to do not prep)
Old 10-04-2009, 11:43 AM
thunderstruck507's Avatar
8.5-8.8 depending on DA, unless you spin
Old 10-04-2009, 03:37 PM
Iwannagofaster's Avatar
i'd say 8.3 if you can hook...post your slip when you get a chance. my stock 99 ws6 pulled 8.5 @ 85 but had amazing traction, 1.9 60 ft on street tires
Old 10-04-2009, 03:50 PM
I dont think this track was prepped good because a lot of people were spinning, but I ran a 8.881 at 83.37 mph with a 2.2 60ft, I didn't do a burn out either I saw no point with street tires, I launched with my TCS on and it helped a lil bit
Old 10-04-2009, 04:21 PM
that 60ft is pretty bad, that's about how mine looks if I spin hard through 1st
next time do a burnout, but just enough to clean the tires...I hold mine at 4k for a couple seconds then let off the brake and run up to 5500 and let off until it hooks (all in 1st gear)
I seem to remember the consensus being traction control will hurt your times more than help them
Old 10-04-2009, 04:29 PM
Tech Apprentice
Thats about what is expected. Don't feel bad, with a track that isn't prepped you can do everything right and still not get good times.
Old 10-04-2009, 04:38 PM
Yeahh but I cant do that with a auto, I was thinking drag radials would help atleast somee, I do also need a tune pretty bad I think
Old 10-04-2009, 06:12 PM
yeah do a burnout next time...it makes a huge difference with me. Idk if its the track or what but my tires get pretty sticky after a burnout. Rocks stick to my tires on the return road
Old 10-04-2009, 07:28 PM
Yeahh that might be from the glue on the track, but ima buy some mickeys DR and see what the difference is lol
Old 10-04-2009, 08:51 PM
why can't you do that with an auto? that's what mine is...
put the tranny in low, hold brakes, get rpms to 4k, nail throttle while letting off brakes, ease out of throttle as you approach starting line, put tranny in "drive", stage
this is assuming you are forced through the water box and wet section of the track
Old 10-04-2009, 08:54 PM
I thought you meanttt something totally different, but the waterbox is way behind the starting line so I guess I could just do a burnout with the water
Old 10-04-2009, 09:29 PM
Tech Apprentice
If you have street tires do not get near the water box. Do a 5 second burnout then ride the burnout as far as you can without passing the line. If you have drag radials, each one is different with the type of burnout.
Old 10-04-2009, 09:51 PM
But if I have drag radials should I just stay away from the water box?
Old 10-05-2009, 01:07 AM
Tech Apprentice
Drag radials I go around the water box (mainly because I have regular tires up front) back up into the water box. Spin the tires over once to get water over them then I pull up and do a John Force. Here is a video of what I do with DRs...
Sorry for the people talking and my g/f attempting to zoom end at the ending. lol
http://i38.photobucket.com/albums/e110/Stopsign32v/th_20090307220434.jpg
Nitto DRs need to get VERY hot to hook (long burnout like above)
MTs don't need near as much of a burnout
And IDK about Hoosiers or BFGs. I really wanna try out the Hoosier DRs though.
Old 10-05-2009, 06:10 AM
well I think I will prolly stick with the mickey thompsons lol I heard nittos werent that good of a drag radial, nothin on hoosiers though
Old 10-05-2009, 11:46 AM
PowershifterNC's Avatar
I do exactly what stopsign does and it works well. I do about a 5-6 second burnout on MT drag radials in 2nd gear
Quick Reply: What Will My Car Run In A 1/8th?
