Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
Power Guess b4 Dyno
Old 10-24-2009, 01:14 PM
DVS BSTD's Avatar
Default Power Guess b4 Dyno
well before I go throw her on the dyno today what do you guys think I'll make?
1995 Z28 A4 79k miles
Stock Y-pipe into True Duals with Bullet Race mufflers
BBK 52mm TB
Jet stg1 Module
K&N CAI
SLP MAF
A/C Bypass
Old 10-24-2009, 01:15 PM
DVS BSTD's Avatar
this is just basically a baseline run before the LE2 Setup
Old 10-24-2009, 01:17 PM
86formula's Avatar
280rwhp? you need some long tubes before you get that LE2 package
Old 10-24-2009, 01:19 PM
DVS BSTD's Avatar
im gonna get some...im just weary of installing them lol
Old 10-24-2009, 01:52 PM
DVS BSTD's Avatar
anymore guesses
Old 10-24-2009, 02:49 PM
CamaroRacing12's Avatar
287rwhp
Old 10-24-2009, 02:52 PM
DVS BSTD's Avatar
what about tq im hoping for 280+ and its 1 little high I think but around 350tq
Old 10-24-2009, 03:43 PM
TravisMcGill2000's Avatar
i say 270 and 310 tq
Old 10-24-2009, 04:01 PM
96capricemgr's Avatar
The Jet and SLP MAF are BAD BAD things, and if you don't hit your goal they are why.
Old 10-24-2009, 04:16 PM
StealthFormula's Avatar
I say 265rwhp with torque at 305. If your running the stock y-pipe you don't have true duals
Old 10-24-2009, 04:44 PM
RamAir95TA's Avatar
That's about where I'd put you too.
Old 10-24-2009, 05:19 PM
DVS BSTD's Avatar
I chopped the stock Y-pipe and ran true duals from the manifold back
Old 10-24-2009, 05:36 PM
RamAir95TA's Avatar
That's an awfully expensive setup for not much gain. Stock manifolds are terrible.
Old 10-24-2009, 05:41 PM
DVS BSTD's Avatar
nah it cost me 100....whats the gain between shorties vs LT's......Are LT's worth the trouble of install
Can you put shorties on while engine is in the car?
Old 10-24-2009, 05:43 PM
86formula's Avatar
you can put LTs on while the engine is in the car lol youll gain around 20hp from manifolds to LTs
Rob
Rob's Avatar
Old 10-24-2009, 05:45 PM
The difference is noticible and with a heads/cam car, the difference would be substantial.
Yes you can install LT's with the engine in the car. Both times I did mine I did not have to lift the motor up off the mounts any. However, if you have access to an engine lift, it is easier to unbolt the engine mounts and lift it up a couple inches. The best time to install the LT's would be when you do the heads/cam swap IMO.
Old 10-24-2009, 05:59 PM
DVS BSTD's Avatar
Baseline numbers are 268/305 with SLP and no Airfoil
Borrowed my buddies MAF and AIRFOIL and 273/308
so either that AIRFOIL works or 96capricemgr was right about the SLP
Old 10-24-2009, 06:01 PM
Damn RamAir95TA and I are good! lol
Considering the airfoil is good for probaly 2-3rwhp, he is right about the stock MAF being better. The stock MAF is one thing I do not recommending changing out for aftermarket piece.
Old 10-24-2009, 06:22 PM
DVS BSTD's Avatar
it feels torquier than 308....must be a F-Body thing
Quick Reply: Power Guess b4 Dyno
