Guess within 5 hp what HP i will bring on the dyno i will send $50 to your paypal.
SO a little background.
I built a 2001 5.3 Iron block engine.
CHASSIS DYNO
Here are the specs,
![Guess within 5 hp what HP i will bring on the dyno i will send to your paypal.-cam001231.jpg](https://ls1tech.com/forums/attachments/dyno-guesses-bench-racing-forum/435437d1469573620t-guess-within-5-hp-what-hp-i-will-bring-dyno-i-will-send-50-your-paypal-cam001231.jpg)
![Guess within 5 hp what HP i will bring on the dyno i will send to your paypal.-cam001241.jpg](https://ls1tech.com/forums/attachments/dyno-guesses-bench-racing-forum/435438d1469573620t-guess-within-5-hp-what-hp-i-will-bring-dyno-i-will-send-50-your-paypal-cam001241.jpg)
![Guess within 5 hp what HP i will bring on the dyno i will send to your paypal.-cam001181.jpg](https://ls1tech.com/forums/attachments/dyno-guesses-bench-racing-forum/435439d1469573620t-guess-within-5-hp-what-hp-i-will-bring-dyno-i-will-send-50-your-paypal-cam001181.jpg)
![Guess within 5 hp what HP i will bring on the dyno i will send to your paypal.-cam001201.jpg](https://ls1tech.com/forums/attachments/dyno-guesses-bench-racing-forum/435440d1469573620t-guess-within-5-hp-what-hp-i-will-bring-dyno-i-will-send-50-your-paypal-cam001201.jpg)
![Guess within 5 hp what HP i will bring on the dyno i will send to your paypal.-cam001221.jpg](https://ls1tech.com/forums/attachments/dyno-guesses-bench-racing-forum/435441d1469573620t-guess-within-5-hp-what-hp-i-will-bring-dyno-i-will-send-50-your-paypal-cam001221.jpg)
-Cyl. Bored .30 over
-Sealed power pistons and rings, .020 top ring .017 bottom rings
-polished crank stock bottom end
-new crank,cam and rod bearings.
-new stock oil pump.
-new timing chain
-Cam 222/230 .596 / .600 111 LSA
-Heads stage 1 ported by lloyd elliott flows 295/210 2.00/1.55 valves, heads not polished. Double springs.
-stock intake and fuel system.
-Shorty headers- True dual exhaust flowmaster 40s no cats
5500lbs truck gmc sierra 1500 4x4 lifted 6" on 315's with stock 3.73 gearing
-4l60e redline clutches, kevlar bands, corvette servo, shift kit, calone steels, Hardend B sunshell, 5 pin planet.
-2200-2500 stall converter
Engine makes 42PSI oil pressure just cranking over with no plugs.
TEST YOUR KNOWLEDGE GUESS WHAT HP IT WILL BRING ON DYNO WITH TUNE WITH IN * (5 HP)* AND I WILL SEND YOU $50 TO YOUR PAYPAL NO BS....
CHASSIS DYNO
Here are the specs,
-new timing chain
I will be dyno'ing it no later than 2 weeks, and seems a lot of people are throwing out guesses and because of this,
The range to be in will be 5 HP, only to make it fair.
Thanks everyone!
Thanks everyone!
Thanks everyone!
Thanks everyone!
