2001 Camaro z28
2001 Camaro z28
Hi i have a 2001 Camaro z28 a4 with a swapped motor out of a 2000 corvette I added long tubes full exhaust Ls6 intake 243 heads btr stage 4 cam 621"/592" 111+3 4:10 gears and a yank 3600 stall torque converter wondering what type of horsepower numbers that would make? haven't dynoed yet still putting car together I know factory the 2000 corvette has 345hp
2001 z28 Camaro
I'm not sure what happened to the original ls1 that was in the car I bought the car with a swapped vette engine and added the additional parts I described. The duration on the btr stage 4 cam is 235/242
Yep, an LS1 is an LS1, no matter what it came in.
You have some stout pieces in that engine, I'd guess more than 400 to the wheels. The major player along with the heads is that nasty(in a good way..) cam. And the intake allows enough air to feed the whole works.
2001 z28 Camaro
So I should be expecting anywhere from 400 plus horsepower i also have a 92 mm tb with cnc'd 243 heads I know the only difference between ls engines is heads.
