TTP Equalizer Stage 3 AFR 225cc Heads/Cam Specials
We have a few sets of AFR 225cc heads en route. These are available on a first come first serve basis. Here is the installed price:
TTP F-Body Equalizer Stage 3 Heads/Cam Package:
TTP AFR 225cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP (Milled to 66cc)
TTP Equalizer V.2 Camshaft
TTP Hardened Chromoly Pushrods
Rollmaster Double Roller Timing Chain
SVO 30lb Injectors
Flycut Pistons
GM Steel Headgasket Kit
(2x) GM Headbolt Kits
(2x) AIR Gaskets
(1x) EGR Gasket (If needed)
GM Timing Cover Seal
GM Timing Cover Gasket
(2x) GM Waterpump Gaskets
Installation
LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$5399.95
We can schedule you in right after the New Year. 973-340-4069.
- Matt
SVO 30lb Injectors
Flycut Pistons
(2x) AIR Gaskets
Installation
$5399.95
- Matt
