Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Progress on my turbo kit...
Old Jun 1, 2005 | 11:03 AM
RealQuick's Avatar
Default Progress on my turbo kit...
Slowly moving. Waiting on some v-band clamps and wastegate.
https://ls1tech.com/forums/forced-induction/330088-progress-turbo-kit.html
Old Jun 1, 2005 | 11:07 AM
PurEvl's Avatar
I look forward to crushing it
Looking good man, coming right along
Old Jun 1, 2005 | 11:11 AM
RealQuick's Avatar
I know Your setup will be nasty. I was debating a T88, but I stuck with the T76. If you spank me too much I might have to add a small shot of the good stuff
Old Jun 1, 2005 | 12:32 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
that crossover looks real low
Old Jun 1, 2005 | 12:38 PM
RealQuick's Avatar
It hangs about 1.75-2.0” below the k-member. Its not too bad considering the Phamspeed LS1 kit hangs over 3” below the k-member.
Old Jun 1, 2005 | 12:54 PM
Originally Posted by RealQuick
It hangs about 1.75-2.0” below the k-member. Its not too bad considering the Phamspeed LS1 kit hands over 3” below the k-member.
shut up........dont tell me what to do
Old Jun 1, 2005 | 01:08 PM
RealQuick's Avatar
What model T76 do you have?
Old Jun 1, 2005 | 01:45 PM
My84Z's Avatar
Do you realise Mike has a camaro with EVERYTHING
Old Jun 1, 2005 | 01:49 PM
RealQuick's Avatar
Old Jun 2, 2005 | 03:25 PM
RealQuick's Avatar
I added like 10 more pics...
Old Jun 2, 2005 | 04:41 PM
My84Z's Avatar
Awesome job man now get started on mine hahha
Old Jun 2, 2005 | 06:00 PM
davered00ss's Avatar
Moderator
put me on the list too. Actually I want Mike's when he gets bord with it.
Old Jun 2, 2005 | 09:29 PM
RealQuick's Avatar
Thanks guys. It has only been about 4 hrs labor (welding, cutting, fitting). Its waiting on parts that suck. I just hope I can give Mike a decent run when I am done. I will be out c.i.'d and out turbo'd.
Old Jun 2, 2005 | 09:54 PM
badpewter-z's Avatar
LS1TECH Sponsor
looking reaaaaalllllll gooood
Old Jun 2, 2005 | 10:01 PM
RealQuick's Avatar
Thanks.
Old Jun 2, 2005 | 11:00 PM
lilstephsls1's Avatar
CT Hotness
agreed.. good luck with it whens it going to be ready?
Old Jun 3, 2005 | 05:16 AM
Slowhawk's Avatar
LS1Tech Sponsor
The only thing that worries me is the crossover pipe.It looks really low.Maybe a 3" oval pipe in it's place?
Old Jun 3, 2005 | 06:30 AM
now clean up those dam welds,and stop using a coat hanger and torch to do it,lol
Old Jun 3, 2005 | 07:29 AM
RealQuick's Avatar
Thanks. Hopefully the car will be done in sring 06'. Labor isnt the problem, its the $20k budget.
Things I have bought, but need to install/finish installing:
Still need to receive my shortblock 383 from HPE so I can assemble the engine and drop her between the fenders
Tial 44mm wastegate
Cold side of turbo kit (which included 50mm Tial BOV)
Need to install in the car (BMR K-member, upper/lower CA’s, Hal’s)
Kenne Bell BAP
Still need to buy:
Turbo Cam
McCleod Street Twin clutch
Moser 9” rear, driveshaft,
6 point cage
subframe connectors, torque arm, adj. pan hard rod
Brakes
Motorsport rims/tires
WB O2 sensor setup
There are more things, just cant think right now…
Old Jun 3, 2005 | 07:31 AM
RealQuick's Avatar
The cross over is a 2.5" pipe, with a flex section that is about 3.25" diameter. I probably shouldnt have put the flex down there...but we'' see how it goes.
