Florida Members Fun, sun and LS1's
track rant
Old Sep 2, 2007 | 09:46 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Originally Posted by deanasdork
i'm a wuss when it comes to dumping.. because of the stock rear ****.
If you want to go fast you have to know that you might blow it up on the starting line, that's the risk you take.
Without risk there is no reward.
Old Sep 2, 2007 | 10:03 PM
Art Vandaley's Avatar
very true.....
Old Sep 3, 2007 | 05:27 AM
camar0corey's Avatar
Ah I wouldn't feel too bad, my 60 out at OSW was around 2.5-.6. Granted my first time out at the 1/4 track, but I wasn't happy running mid 14's@103mph.
Old Sep 3, 2007 | 09:03 AM
might as well just go ***** to the wall and just dump the clutch and go worst case scenario i break it and just sits in the garage a while.
Old Sep 3, 2007 | 09:51 AM
35thUCF's Avatar
try a different lane? i always seem to run faster tower side
Old Sep 3, 2007 | 10:43 AM
UCFWS6's Avatar
yeah I would go for the MT DR's and dump it. I'm putting down less power to the wheels in an A4 and managed a 2.0 60'
Old Sep 3, 2007 | 10:49 AM
ND4SPD _SS's Avatar
OSW does suck as far as traction goes, especially when it's hot. I used Nitto DR's to hit my 11's on juice and 12's on motor. I had no problem with them. you just need alittle more practice. don't get discouraged. good luck.
Old Sep 3, 2007 | 11:17 AM
I wouldn't dump the clutch, just do a fast slip.
That's how I ran 12.35 @ 113 MPH with a 1.78 60' with my bolt on full weight 3:73's 98 Z28 with a full tank of gas. The car dynoed 336 RWHP 348 RWTQ without a tune (only thing available at the time was Hypertech) Tires were 16" Nitto DR's.
Do an 8 second burnout at 5-6K rpm, roll straight to the line, bring the rpms to 4500-5000, as you let the clutch out add more throttle the clutch should be fully engaged and your foot should be to the floor within the first 5-8 feet of movement. If the car bogs bring the rpms up until you find what the car and track will tolerate.
If you want to be more consistent invest in a shiftlight. You want to have it come on 200 RPMs before you want to shift, by the time you see the light and actually shift should be no more than 200 RPM.
It takes practice and the inconsistent prep at OSW doesn't make it any easier.
When you have the $$$ get yourself a Moser 12 bolt and have Donny over at Advanced Driveline set it up, don't have it done by Moser. Then throw some slicks and skinnies on and side step the clutch at 7K........now that's a fun ride.
Good luck.
Old Sep 3, 2007 | 12:07 PM
3fingas's Avatar
Get better on the tree, practice, practice, practice, it will help with ur 60. With those who think R/T has nothing to do with nuttin. R/T can determine whether you win or lose. Remember the clock starts when your green and if your sittin then your losin
Old Sep 3, 2007 | 12:12 PM
mrr23's Avatar
again, RT has absolutely ZERO to do with ET. they are two different clocks. you can sit there for five minutes and until you move the car and break the ET timer beam, the ET timer doesn't start.
so again R/T has nothing to do with nuttin, when it comes to ET. if you were bracket racing, then it plays a role. but ET, it makes NO DIFFERENCE.
Old Sep 3, 2007 | 12:18 PM
gator's 99TA's Avatar
maybe this is how its taught in da bronx, but the rest of the tracks across this country - R/T has NOTHING to do with your Elapsed Time or MPH.
sorry homes.
Old Sep 3, 2007 | 12:19 PM
  #32
mrr23's Avatar
sorry homes.
Old Sep 3, 2007 | 12:20 PM
  #33
3fingas's Avatar
IMO Im sayin his r/t could be better. All it takes is practice.
Old Sep 3, 2007 | 12:23 PM
  #34
mrr23's Avatar
um, if that was the case, then why did you say it'll help with his 60ft? maybe we are missing something here....
Old Sep 3, 2007 | 12:24 PM
  #35
mrr23's Avatar
and what about this?
Old Sep 3, 2007 | 12:32 PM
  #36
3fingas's Avatar
I dont know where you people learned how to race, but its obvious you never made any money doin it. I understand that physicaly it has nothing to do with his et. However. if his (not the car) reaction is faster, he will be at wot faster. from his times vs. HP he should be quicker correct? Assuming he is in the grove and the car is hooking up. Sounds like he needs a lock.. Don't hate...Ejaculate!
Old Sep 3, 2007 | 12:33 PM
  #37
LivingCanvas's Avatar
THE CLOCK DOES NOT START WITH THE GREEN!!!!!!!!!!
The clock starts when your front tire rolls out of the staging beams. Jesus christ
Old Sep 3, 2007 | 12:37 PM
  #38
mrr23's Avatar
maybe because we learned it at the track. not at the stop light.
just for you. the two timeslips on the left. why did i go slower with a quicker RT? spend some time on the track.
Old Sep 3, 2007 | 12:44 PM
  #39
3fingas's Avatar
Only you can answer that, Maybe you spun who knows. Just forget it.
  #40
92slowmaro's Avatar
your annoying
