Yank PT4000 or 4400?
Well went to the track wednesday, I did a little bit better than before in similar weather, but not what I was expecting. Anyways, I feel this midwest 3400 stall is holding me back. After some reading I'm pretty dead set on the PT series converter from Yank, now the problem is which one? No, no nitrous is in my immediate future. It will be, but a whole other setup will be in by then. So what do ya'll think? PT4000 or PT4400?
mods: ms4 cam, stock heads, ls6 intake, p&p tb, longtubes, dual exhaust, 3.73's, and lid.
Numbers in sig ... my best run with the previous SS3600 was 11.875. My ONLY run with the new PT4000 produced the times in my sig. And I only stalled it to 2000 rpm and mash easy into the pedal. Next time out I am expecting consistent 1.x 60' times and a much better ET when I stomp it and let the converter flash to it's full potential.
Major difference between the Yank SS and the ProThruster series. The only real noticeable difference in driveability to me is no more low end to 2nd gear, which was killing me against M6 cars ... now, the A4 rocks and no more 'dead spot' between 30-40.
Either stall size you'll love in the PT series converter.
I'm trapping a little better, but, on a really easy launch. I haven't smashed the pedal violently ... yet. I think my trap times will go up to about 118-119 ... cutting agood 60' time, I should be running 11.5's without much problem. Of course, we'd always welcome better numbers, right?
If you're looking to go faster and for better shift extensions, then, you've got the right converter in mind and prob should go with a 4400. Since I went with the PT4000, the car just rows right through the gears. Before (with the SS3600), the care would jerk when it shifted on 1-2 shifts. The slight loss of momentum caused a need to re-gain the momentum to keep the car moving.
Now, the shift extensions are there and the car just feels like a different f**cking animal. Go PT4400 and I think you'll be glad you did ... it's not gonna' feel a whole lot different from the PT4000 ... just better IMHO.
Totally agree. Original converter went on with bolt-on's and worked great. Went from 13.1-2's to 12.6-7's. I figured it was enough to get by with the MS4, but it seems it's hurting me a lot more than I thought. I've ran a best of 12.0@114mph BEFORE the better tune, 3.73's, DR's, and subframes in about -400 DA. The worst I've ran with the cam has been 12.4-5's in really warm weather in the daytime. I've gained about a tenth and 1mph since the new mods....but I haven't been able to launch hard due to air in my abs module that I haven't got rid of. I've got a soft pedal and the front brakes just won't hold beyond 1400 when I footbrake (footbraked it to 2200 before I added the line lock and got air in the abs) so I couldn't muster better then 1.84 60' with the DR's. I've got an ABS delete kit sitting on my desk here waiting to solve that issue though!
