guys with vented rocker covers inside
Old 04-04-2010, 09:15 PM
  #61
Tally TransAm's Avatar
ran a -8 from the rear of the ds valve cover and the front of the pass valve cover to a vented can. seems to be working good so far, have about 2k miles on the setup
Old 04-04-2010, 10:45 PM
  #62
conan's Avatar
Originally Posted by LSXFORMULA99
on my procharger it says a line gos to the passenger side valve cover vent connector
There is a spot on the filter hat for the blower that they tell you to hook up to the pcv but I didn't want any thing getting sucked in to the blower other than fresh air.
Old 04-04-2010, 10:48 PM
  #63
conan's Avatar
Thats where I have my rocker covers vented from and haven't had a drop of oil come past any seals. Nice looking can set up BTW.
Old 04-05-2010, 11:00 AM
  #64
LSXFORMULA99's Avatar
whats that supposed to help? should i just plug the hole on the filter hat
Old 04-05-2010, 11:51 AM
  #65
conan's Avatar
Ya just cap it off. I took some fuel hose and put a bolt with RTV gasket maker in the end of the hose and hose clamped the bolt in place. Then hose clamp the other side of the hose to the nipple on the blower hat.
Old 04-05-2010, 01:05 PM
  #66
thanks man.
Old 07-07-2010, 10:16 AM
  #67
2XR95Z28's Avatar
here is how my vented can is setup... one -8 bung welded in each valve cover towards the back and -8 line ran to the allstar vented catch can. Haven't started or ran the truck yet but thinkin this should be sufficent...
Old 01-23-2011, 09:20 AM
  #68
Adam86's Avatar
I keep looking but can't seem to find the answer. Does anyone know the conversion from AN to inches? I see a lot of guys running -8 to -10 an lines for their venting. I plan on using 3/8" hose to ventilate mine and am hoping that will be sufficient. Thanks!
Old 01-23-2011, 11:12 AM
  #69
mr_biscuitz's Avatar
-8 is more like 1/2'' and -10 is 3/4''
Old 01-23-2011, 09:31 PM
  #70
boostedLSX's Avatar
3/8 is the same as a -6an hose
Old 01-23-2011, 09:46 PM
  #71
Adam86's Avatar
Thanks guys!
Old 01-26-2011, 08:48 AM
  #72
Rick_Vor's Avatar
Add a "/16" to the -AN (ARMY/NAVY) number to convert it to inches.
-6AN = 6/16" = 3/8"
-8AN = 8/16" = 1/2"
-10AN = 10/16" = 5/8"
-12AN = 12/16 = 3/4"
etc, etc, etc
Rick
Old 04-13-2011, 03:11 PM
  #73
67Firebird455's Avatar
Great info... you guys change your oil often with this catch can setup eliminating your PCV all-together? By reading through this, a lot of FI guys are going to the twin valve cover to catch can with a breather setup. Think I'm about to take the plunge!
Quick Reply: guys with vented rocker covers inside
