New car for 2009 build, D1SC/347
#182
Been finishing up some little things, made a cover for the ugly PCM connectors, put a Odessy 925 battery in. Its 8lbs lighter than the stocker but has more oomph than the usual PC680 battery. Also mounted the intercooler and trimmed the front bumper so the front is done. So thats about it for the most part, except for an engine anyhow
#185
100% done except for the engine now, should have the short block here in a week or so. I even aligned the front end so I'm really running out of things to do, I hate doing front end alignments
Ended up used the cold side pipes the Forcefed98 here made for his car a while ago, figured why fix what isnt broke. I changed the old vortech mondo out for a procharger bypass and thats about it.
Rolled it outside and waxed it yesterday and did the final detailing on the interior. Now I can say its 100% done except installing the engine/trans. Decided to go ahead and go ahead with some AFR 225 small bore heads, picked up a deal on a set of used ones and a set of used Kooks 1 7/8 headers as well so this will pretty much be the same as my old 347 setup. We'll see in a few weeks I hope
#186
LS1TECH Sponsor
Looks good. Anxious to see some videos from the track when all finished up.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
#188
Yea thats the trans overflow, I have it mounted high so it drains back into the trans, TCI makes one that bolts next to the trans pan on a 400 but you have to drain it once in a while naturally, and I dont know how much it hangs down.
#199
LS1TECH Sponsor
LOL I can't wait to see what this one is!! I just hope it's a Procharged LS of some type!
__________________
