New car for 2009 build, D1SC/347
#263
I posted the first time out videos a while back, it ran 6.29 @ 111 first time out not really pushing it:
http://videos.streetfire.net/video/4...-TN_644603.htm
I'm going to take it out again today and see what happens I think, its a nice day..
#266
Thats on 50/50 93 pump/104 sunoco unleaded, thats all I had. I have some unleaded VP109 this time so I'll step it up a little.
it was around 13-14psi, the MAP sensor in the logger was kind of screwy, I'll have a better idea this time. Timing was was 14* degrees at peak and 22 @ 4500rpm, so it was a really soft tune. It all depends on how well it 60 foots really, these tires I have on it are pretty old DOT QTPs, I'll run them one more time and switch to slicks, I'm just going today to collect some data and enjoy the weather..
#268
I dont know, I tried it open and with an inlet I made that 'looked' better than the procharger piece with the same results - no gain. I had a car that ran with .01 every pass and it was easy to see a gain and easy enough to do at the track, trust me if I could have ran .05 quicker in the 1/4 mile i would leave it open or use the better inlet I made.
#269
Did a little better yesterday, power is where I want it (112-113 in the 1/8) so know its time to work on the horrible 60 foots a little. Car isnt hooking at all, 1.410 was the best yesterday, should be in the low 1.3x range.
http://videos.streetfire.net/video/L...909_647263.htm
last pass was a 6.22 @ 112.5 and they didnt switch the timers to 1/8 mile so I coasted through at a 10.08, If I knew I would have stayed in it a longer and got a 9 second pass..
I am running a Y-pipe into a single 3" muffler and thats not the best exhaust out there. I'm pretty happy overall, just need to get the 60 foots down some, have to spend some time on the suspension and put some new tires on it..
#270
#272
Looks like you were on the brakes and you could hear you let out of it. Easily a 9 second pass, just how deep into the 9's is the question.
#275
Thanks Kris, hope to see you around this year. Seen some nice pics of you car someone took on SCF, looks great.
Here is a few '100% done' underhood shots. First time out to the track the belt came off on one pass so I put a Katech tensioner on it and that stopped that 100%. Also added the lingenfelter 2 step, another great product, plug it in and hook up one wire to the trans brake and it works - cant beat that.
It was nice to take the radiator cap off this morning and see the coolant all the way to the top and not smelling like exhaust, if I can keep myself under control hopefully it will stay like that for a while. Going to put some new tires on it next week and that should help more than anything right now..
#278
Not sure what you mean by 'hot piped' though, if you mean no intercooler there is an eBay A2A on the front.
It turned out nice, could have done it a little quicker but I'm glad I took my time and did things the way I wanted to do them. I'm like most people and just want to get it done once I start on it
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
