Superchargers/Whipple/ATI Procharger
I was wondering what i should go with when i get a supercharger. I have a 2000 WS6 LS1. i heard that the ATI procharger was one of the best ones for an ls1, but i also heard whipple made a good one. i wanting to make some serious h/p out of one if im going to be spending the money...what do you guys think???????
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I say procharger is the best supercharger for the LS1, if you plan on making some serious HP in the future get the tuner kit, and might even consider getting rid of the D-1SC head unit for the F-1, but if you plan on staying stock motor, stock C.I. you will be fine with the tuner kit....
You will need bigger injectors, new fuel pump, some dyno tuning, the list can go on and on...
If you don't want to worry about belt slippage, and if you don't plan on making over 600RWHP anytime soon, I say Vortech V9. If you move up to more than 600, you can always upgrade to Vortech T-Trim.
SSU Moderator
a custom kit is what you want for big power. I would do a V9 up until 550rw...above that...move up to a T-Trim I'd say...and ditch that 'aftercooler' for a real cooler, air-air or another air-water with a good pump and feeder tank. I think the vortech kit needs a better air inlet as well.
the ATI kit is good...until you get some rpm going and the brackets move and you start shredding belts. one dude on there has a vortech and is pushing the G past its max rpm with a little tiny 2.5 or 2.75" pulley...8-rib. no tricks or cogs or whatever, just a good bracket and well designed pulley system.
The Vortech kit is a very good choice. It comes with everything you need for the install including programming and injectors so you don't have to worry about ordering anything else. ATI makes a good kit but they don't come with injectors, a fuel pump or programming. Those items have to be purchased seperate.
Whipple currently doesn't have a system for the f-body. That would be nice though!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
By the way, the water pump is a SHURflo.
Works great (albeit it's BIG)! I got from Bill Anderson Racing in Baltimore, MD.
You could. Magnuson tried this on an f-body. I don't know if they ever got one on a car but it got to a point where they had to remove the wipers and modify the cowl. Anything can be done though ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I am mulling over a T trim, with an air to air. I already have the fuel pump, injectors and LS1 Edit can take care of the programming.
Where can I get my hands on a mounting plate and install kit for the T trim? Can I get a cog belt system to fit?
The Procharger just has too many issues with belt slippage. I dont want to lay out $4200 for the tuner kit, only to spend $$$$ replacing belts constantly. My friends Procharged Trans Am is down more then up, due to belts shredding.
