project tin can shootin for 9's
OP i have gotten a bit of flack about weighing the options of powerplants and my feeling is it's still GM hell even ford boys are doin the same:
way easier tunning,more power to be made due to head design plus a few other ways. this is not disrespect to the Lt1 this is makin me happy on my dime
Thanks again.
I would like to do what T UNIT has done and get a LS based engine but this car will stay LT1 to the end.
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
--still waiting on parts to come in. Got the ls6 intake manifold with aeromotive fuel rails, 60lb injectors, stock ported TB. Also a little pimp factor, we pulled out the top tube and tapped it so i can run my boost gauge off of it. So no extra bungs welded on the turbo piping and i made use of that hole...
--Yella Terra shaft mounted 1.8 rockers
--Custom one-off aluminum th350/lsx crossmember made by Eric@midwest chassis
--Stock style sumped aluminum gas tank which will have a aeromotive A1000 pump feeding the 60lb injectors. I should have enough fuel for anything i put in there..
