project tin can shootin for 9's
Old Jan 31, 2009 | 12:58 PM
  #161
jrob56's Avatar
Good choice going with the lsx, cheaper, easier to tune, and will make more power. Ill be watching this thread now
Old Jan 31, 2009 | 02:09 PM
  #162
LSWHO's Avatar
Originally Posted by Taubr Unit
im not hatin on ya, i can see where your coming from, id feel the same. But put this into perspective, i sold my engine for a $1000 and bought this one for $340. A cam alone in this will make more power then most H/C lt1's. And no more opti, or shitass obd1 computer to try and get someone to tune, 15deg. heads, 6bolt mains and the list goes on.
I completely understand WHY you did it. I just am not impressed with fast LSx, that's all.
But, hell. If you want a lot of power, this is definitely the way to go.
Old Jan 31, 2009 | 02:58 PM
  #163
joelster's Avatar
x2.
I agree with your decision totally, it's just not impressive seeing an LSx car running 10's. It's almost as though they are expected to when you see one with slicks and skinnies. To see an N/A LT1 car running 10's, that draws some attention.
I'm not taking shots here either, just busting your ***** a little. I'm sure in the long run it will be cheaper and run the numbers, I just wish you'd have kept going with the LT1 build.
Old Jan 31, 2009 | 03:09 PM
  #164
z28rob18's Avatar
x3
i think fast lsx cars r a dime a dozen. but i would have done the same im build my lt1 with a high 9s goal but when that gets old and i get the money im goin lsx. how can you beat a motor that can run 10s in a 3xxxlb car with only a cam? ill be lurking on this thread lik ive been i enjoy the project threads especially this one
Old Jan 31, 2009 | 03:15 PM
  #165
CamaroRacing12's Avatar
whats the advantages/disadvantages and differences between the 5.3 and the 5.7 LSX?
Old Jan 31, 2009 | 05:28 PM
  #166
Taubr Unit's Avatar
the 5.3 is a ls1 just a smaller bore, but same stroke. Bore a 5.3 a little over and youll have a "ls1" with a iron block. And price, a complete 5.3 can be had all day long for $500 with low miles. A low mile ls1 is still $1500+
Heres a car im really following...
http://www.theturboforums.com/smf/in...?topic=80049.0
Old Jan 31, 2009 | 05:30 PM
  #167
wichoms4's Avatar
great job. thats a very big diet you put her on. keep us updated.
Old Jan 31, 2009 | 05:42 PM
  #168
whats the weight difference between the iron block and the aluminum block?
i could of gotten a 5.3 block for free a few months ago but i passed it up... im an idiot... i shoulda just got it and bored it out and starting building a nasty N/A LSX motor
Old Jan 31, 2009 | 06:40 PM
  #169
z28rob18's Avatar
so after skimming through the whole thing i noticed some thoughts about a turbo you turboing this motor how much boost HP goal? i see this car havin some incredible potential for low 9s
Old Jan 31, 2009 | 06:41 PM
  #170
Taubr Unit's Avatar
yes sir, shootin for at least high 9's
Old Feb 4, 2009 | 07:28 PM
  #171
Taubr Unit's Avatar
not much progress, waiting on a lot of parts, but heres the motor.
-'01 5.3
-all ARP bolts/studs
-ls6 intake
-60lb injectors
-full valvetrain
-220ish cam
-EWP
-low mount alt.
-truck manifold turbo kit
-Turbonetics TC76mm Turbo
LET IT BEGIN!!
Old Feb 4, 2009 | 07:47 PM
  #172
Hot94Z28's Avatar
-'01 5.3
-ls6 intake
-60lb injectors
-full valvetrain
-220ish cam
-EWP
-low mount alt.
LET IT BEGIN!!
Whatever you choose to go with it is always fun to go fast.
Old Feb 5, 2009 | 06:35 AM
  #173
pwrtrip75's Avatar
Low 10s should be pretty simple also. My car weighs 3660 w/ me in it and runs 10.30s. With thrown together parts. 5.3L GT45 turbo and a 224/224 .580 112 cam, 4000 stall. Its also blowing through the converter pretty bad, 131mph on a 29.5 tire 3.50 gears and 7500rpms through the traps. You should run mid 9s with ease being that light. I wouldnt have wasted all the money on studs and valvetrane. Mines going on 3 years of beating with bone stock everything except the cam and patriot gold springs.
Old Feb 5, 2009 | 06:43 AM
  #174
pwrtrip75's Avatar
Why are there LSX haters on LS1tech?
I had the same argument a few weeks back with someone. You think back in 1960s there was a group of people thinking the same thing?....They all ran flat heads and were mad at the SBC and it was an easy way to go fast? Its called envy.
Antiques are cool but everyone knows they are not practical.
Old Feb 5, 2009 | 06:47 AM
  #175
Black94Z28's Avatar
you going to have this drivable this year? would like to run you at GLD, although right now i think u have the upper hand
Old Feb 5, 2009 | 06:36 PM
  #176
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Looking good! Can't blame you for going 5.3, I would if my brother didn't have the LSx catagory covered!
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Feb 5, 2009 | 06:45 PM
  #177
Taubr Unit's Avatar
its not so much wasted money.. its a must to run new springs retainers etc, and must run new pushrods, so whats left? Rockers and lifters. Lifters i got new and cheap from a member on here and rockers i got super dirt cheap cause its a real good friend of mine. So with tta being said i got a complete valvetrain for next to nothing. As for the head studs, i didnt really want to pull the heads off but the motor has a ton of carbon build up so im sure its not the freshest motor in the bundle. So to play it safe im pulling the heads off to get them cleaned up some and then check everything to make sure its all good. So why spend the money on new head bolts when next winter im pulling them back off... so if i buy the head studs now i wont need them later. Kinda a "need them sooner or later, why not now" type of scenario im in.
Old Feb 6, 2009 | 10:22 PM
  #178
ryans01z28's Avatar
looks like a lot of work. good luck and keep the rubber side down
Old Feb 6, 2009 | 10:27 PM
  #179
z28rob18's Avatar
alright you got me im envious and jealous lol i just love reading about fast cars.
and did you buy the motor with all that done? or you put it together?
Old Feb 6, 2009 | 10:56 PM
  #180
Puck's Avatar
Now you just gotta start really modding that little stock 95 and turnin out the serious times .
