project tin can shootin for 9's
Example:
https://ls1tech.com/forums/drag-raci...or-update.html
got my th350 in. RMVB with a trans break, vig. 3800 stall converter and a cheetah shifter. Going to wire up my nitrous up to the trans break so when i let off the break the nitrous comes on, thats gonna be FUNNNN!!! WHEEEEEEEEEEEEEEEEEEEEEEEE!!
yes sir! Just slides right down into place then bolt on the top straps and off you go!! Only took me 3 days of staring at it to come up with something. Its pretty tricky when your trying to mount a flat bottom radaitor to a piece thats angled a lot.
After researching a ton im changing it up. I bought a 5.3 lsx motor and do a turbo 5.3 set-up.
Shootin for low 10's now. So i didnt completely sell out to a ls1 but now i join the lsx community now. 5.3s are super cheap. There was a complete running engine on my local craigslist for $300. I sent the guy a message, but it had already sold. Congrats on making the correct choice.
I have the perfect turbo for you if you are looking for one. It's a GT4202, 74mm, T6 flange, 1.15 AR that's just been rebuilt and has zero miles on it. It's rated to 1000hp, but will work well on smaller engines. A guy in the forced induction section has one on his stock LS1 and it put out some nice numbers. The info and pictures are in the link in my sig.
