project tin can shootin for 9's
Those look a lot easier than the racecraft rails to get everything installed
I sold my.aluminum driveshaft and going with a cromoly Strange shaft this time around. I want ABSOLUTELY 0 issues this time around and this should do it!
What was wrong with the aluminum shaft?
Just curious cause I broke my chromoly shaft and am now going to a aluminium one.
As far as shafts go my aluminum one was fine and real light, I just want to go stronger at this point (how you broke one is beyond me, lol). Was it a chang-**** one from somewhere?, u don't see a good shaft breaking unless it was misused or just bad luck?
On the opposite end, i had to drop my trans off to get the front pump back in from it being pulled out from taking off the old bell (sold the sbc one it came with) so i got a call today saying that it done so ill get that back early next week. Eric said my cross member should be done next weekend so just maybe by next weekend ill have a trans back in my car!
As for my drive shaft.....well for w/e reason my stock th400 bell broke at about 100mph mid pull. I think when it cracked and the trans angle went all crazy the drive shaft snapped right in the middle, made a clean cut and trashed my floor. It didn't break because of power.
As for your shaft, under those circumstances, I don't think any metal would've lasted that ****, lol.
At first I thought ive made a big mistake tryn to save $ but looks like I might be alright. Either was jegs lets you return stuff for a year w ith minimal fees
Its been a while since i did anything here but now im just about finished. After getting royally screwed over on my trans i bought i finally got that back a little while ago after it cost another $900 to get fixed. Weird thing is it was a "fresh" trans, only to find out 3rd gear was smoked due to the converter getting pushed into the pump and sending cast shavings through the entire trans, so $900 on top of the "fresh" trans kinda set me back. However now that whole **** fest is over with and now have a 2k rated th400...
After i get that sorted out i buy a BMR th400 crossmember that fit like complete garbage so after grinding the holes bigger and making spacers i got that to fit finally....
Now as of today i picked up my driveshaft. Its a 3.5" chromoly driveshaft with fordged ends and yoke. This is a BEAST of a driveshaft!!
So now that i have all the parts, all i need to do is get the shaft in the car, add fluid and go test. Hopefully in the next few weeks ill get new times on the car. Curious what itll do when i can finally let the car eat and up the boost!
Overall im happy i changed from the th350 to the th400, originally the th350 was bought for my cam only lt1 but since then i changed directions so many times that the end result wouldve killed the th350, lol.
