pro charged lt1 stock bottom end
I had a d1sc on a stock 93 lt1 and was running 8 psi, made 450 rwhp. Ran good for 2 thousand miles, then performance started to suffer. Did a leak down test and 2 cyclinders showed lowered compression (cant remember how much PSI showed in those cylinders)
Pulled the engine and the ring lands looked ok, but was getting blow by. Had a pretty rich tuned on the safe side, but I would say the majority of boosted stock bottom end lt1s out there end up rebuilding at some point.
I put 45,000 miles on my 96 Impala with 10 psi Vortech kit on. I never did blow the motor. I pulled it, too make it faster. The LT1 cast piston is the problem. Its only a matter of time before you break the ring lands. I think I got very lucky.
BTW the stock engine had about 60,000 when I put the blower on. The ring lands never broke, the rings couldnt keep up with the cylinder pressures.
theres a car i think im going to get, its a 97 z and has a twin cooled pro charger. the car has 56k on it and its only had the pro charger for about 4k miles. said with 5psi it mad 467 rwhp , has cam and heads have been worked, headers, x pipe. so i could probably bump it up to 8psi and be good for a while.
At 4 psi, it will live forever with a conservative tune. Anything above that and the pistons just won't take it for any extended period of time. Though, a while back some guy claimed he was running 12 psi on the stock bottom-end and it lived for a while. However, his dyno and track times were also very fishy too, so I wouldn't count on yours doing that too.
LS1TECH Sponsor
Been at 9psi for awhile but mostly track time.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
LS1TECH Sponsor
Jon
__________________
