Rear mount turbo setup, oil return pump suggestions?
Hey everyone,
I'm in the process of gathering parts to built a rear mount turbo setup (like an sts, but doing it myself). I decided to do it this way after seeing a couple kits and how they worked, and also not wanting to hack up the car. Does anyone have a recomendation on a brand of oil return pumps? I have searched quite a bit, and of course everyone says their brand is the best. I would like to hear from someone that has one and has put some miles on it. This is a daily driver, and obviously if the pump craps out, you are stuck!
Thanks for any suggestions.
Jason
Jason
Does STS sell their pump outside the kit? I had heard it was just a rebadge pump that they buy from someone. I looked up the mocal pump, 178 bucks, I was expecting to spend around $200. I'm not going to rely on a $50 ebay piece of crap that can make or brake the car getting home!
Any other brand suggestions I'm open to it.
Jason
Jason
You can always use a rearend scavenge pump like they use on race cars. Same thing Callaway did on the twin turbo vette. This is what I plan to do also, dead reliable mechanical system if that is requirement for you. Just don't pull alot of vacuum on the suction line though from what I have been told, don't know how true this is yet though.
I think its going to be between the shurflo and mocal. I have heard of the shurflo and it looks like a quality piece. I'm going to do a bit more research before I buy.
Thanks everyone for the info and suggestions.
Jason
Jason
mocal look up schantins thread on the write up great help make sure you use the 25 amp fuse if you go with the mocal pump and get a good piece of flat rubber to mount it to to quiet it down also make sure you through bolt it. the shop that did the initial install of the sts on my car before I bought it did not and I was dragging it down the road one night. also when you have the carpet up put dynamat or something under there to help quiet it down ot is loud though. Don't forget the .65 restrictor for oil; line this will help oiling issues.
If you want the same pump sts uses, PM me for a link as it's non sponsor. STS won't sell them to you unless you can prove you own one of there kits. There are not a diaphragm pump, like the pumps above, but a true, spur gear pump with bronze gears and a ss shaft designed for oil and fluid transfer. They are pricey at about $290 though. They've gone up about $100 in the last year
1 Post
On a SD equipped car it's worse. There isn't necessarily any loss of power indicators, but the atomized oil is introduced into the intake and then the combustion chambers. Oil has a low octane rating and can produce detonation......which will jack up the engine.
Oil in the intake is also a real pain on a FMIC equipped car. Takes a while to blow all the #$%^ oil out of it (know from experience ).
The above is why oil control is such a big deal on STS kits in particular.
I had thought about a separate system, but thats alot of plumbing and work. I have talked to a couple other members on here that have been running rear mount setups for a while and am pretty sold on the shurflo. I do plan to install a indicator light for the pump that will light up when the pump is running. If is shorts out or craps out and blows the fuse the light will go out and its time to stop. I have heard the pumps can keep making noise but not be pumping oil, so I will just have to pay attention to the car when driving. If a big cloud of smoke starts to appear behind me, its time to pull over!
Jason
Jason
