Are LQ9 heads any good?
I've got a 99 TA and fixing to put a sts turbo kit on. Just trying to find some info on heads and possibly cam on a budget. The reason for the budget is a stroker in the future, but anywayz. Are the lq9 heads any good, and I heard that a 02+ ls6 cam is good for a budget boost cam??? Any suggestions would be of great help.
I have made over 800+rwhp with them several times.
TC76 Turbo
8.5:1 370
LQ9 heads
918 springs
TU1 Cam
At 15 lbs it made 770rwhp.
At 20lbs it broke 800rwhp.
450-550 max is a friggin joke, We do that on the stock long block at 8lbs and pump gas.
8.5:1 370
LQ9 heads
918 springs
TU1 Cam
xhk651: more than a strict budget will safely allow..
on a small budget built correctly you will be looking at about 450-550 max, depending on the money..
Budget doesnt change. Only the tune from Safe to Ready To Blow. Opinions very. This I know. If you want to tune your setup to be safe at 450-550rwhp that is totaly cool. I can safley make 550+rwhp. Its all in what you want.
i know you know a lot more about turbos than i do..
jason has told me you know how to put your **** together..
i would just think after 550 or so, then you would need injectors, fuel pump, etc.. and thats where the "strict budget" is starting to get stretched a little..
i dont know much at all about turbos.. i like N/A, and a little bottle..
I just recently turned my boost up to 15psi and and so far so good.
I am running 317's that I ported a little with arp head bolts, 48lb injectors, 340l pump and pump gas with no meth and on a built 10 bolt. I am still running 10.0 afr and no knock to speak of. I dont plan on going any further on my stock 113k bottom end as I am pleased thus far. I am blowing through the convertor now that I raised the boost 5psi(4l80e).
Oh well time to upgrade.
Trying to test the limits of componets and proving it can be done with a relative cheap setup.
ive made good power with 317s but as far as boost goes i 12psi on a stock short block and its holding up well but its all in the tune
i think it would run better with less boost and a tune change (more timing and less fuel )
i say get 317s run 8-10psi with some meth and a good tuner you can make 600rwhp easy
my ride has made 694rwhp with 317s and ZO6 cam at 12psi but we turned it down after that LOL
hope this helps
hope this helps
