Camaro SS F1-C Build
#287
It's been way too long since the last update!
(Knock on wood) the car is running the best it ever has! The Transformance 4L80 is in the car, and Jake's transbrake works great! The car went on the dyno earlier this year during a Mustang dyno day (dont ask...) and was down over 100whp. Turns out the K&N air filter had been sucked in and was acting as a major restriction. After a quick fix, the car went back on the dyno, boost is back up at 16.5-17#'s and no belt slip! Unfortunately, the car is making too much power for the converter that's in the car (dyno issue only.) Through an UNLOCKED converter the car made 785 whp.
Just a few more upgrades needed before this thing finally sees the track... I am having bad heat issues while the car is at idle or city driving. I've managed to maintain good temps while cruising at highway speeds, but need to find a way to keep this thing cool while standing still.
My second issue is STOPPING! Jesus Christ thing car doesn't want to stop! I've ordered a set of Hawk pads, and plan on bleeding the brake lines... Hopefully it's just as simple as that.
#288
LS1Tech Sponsor
Make absolutely sure the fan is blowing the right direction, it should be drawing air (puller) through the radiator, not blowing air into the radiator. It can even appear to be drawing air through when the air bounces back off the radiator. This is normally the problem when the symptoms are as you described. If it was 90+ outside and you were stuck in heavy traffic with the a/c on, then I'd say it would be a lack of enough fan cfm. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#289
#291
Yeah, it has the 160 degree thermostat... And the stock fans (i would imagine) should be moving more than enough air to keep that motor at a decent temp... I'm worried about sitting in the staging lanes, the car will more than likely see 130+ if it's a long enough wait... Even turning the car off, it will still be way too hot to run wide open.
I'm thinking about standing the radiator up all the way, and possibly adding a pusher (assuming there will be enough room with everything being cut out up front.)
#292
#295
LS1Tech Sponsor
__________________
#296
So, I'm going to attempt to bring this back from the dead... I don't know what hit me, but my interest in this car has smacked me in the face recently...
I'm currently looking for help in choosing a suspension setup. I've spoken with a couple of vendors, who have pointed me in the direction of "Viking" shocks/coilovers. Does anyone have any experience with these guys?
Also, looking to do an ABS delete in the near future. With any luck, I'll have her back and better than before in a short time.
#298
Ordering a full set of Viking coil overs Monday, once those are set up and suspension is dialed in, she's going for a paint job. I leave for vacation middle of June, so hoping to have it back on the street by July
Still needs 2 step, abs delete, and a new set of pads before she sees the track
