Please help design a F1r pro charged ls3
Hi I am wanting to build a pro charged LS3 based engine and have little to no knowledge on Ls engines. It will be going into a 69 camaro.
Regards
Greg
Regards
Greg
The car will See a bit of everything auto cross, drags and cruising, it's being built with a ten point cage, triangulated 4 link rear and a 4l80e trans. I am hoping for around the
1000rwhp.
Regards
Greg
1000rwhp.
Regards
Greg
The LS3 is a great platform for your build. What rotating assembly are you going with? What compression? Heads? I just built a LS2 418 cubed with Eagle crank and H-beam rods and Arias pistons. Compression is at 9 to 1, I'm running All Pro heads with a FAST 90 intake and LS7 TB both ported. The head unit is a F1A with a innovative crank pulley and 8 rib setup and I'm very happy with the out come.
At this stage I dont have anything at all, the car has a 509BB in it at the moment and I am looking to go Procharged LS on pump gas. As I say I really have no idea on the LS motors and Iam looking for as much input as possible. I really wan't to get it right the first time. I stated LS3 because I have them in my dalily drivers (VE SS Comodore sedan and VE SS comodore ute) and I have heard good things about the avaliable performance. I am open to all suggestions (ie) aftermarket blocks ect, but I would like to stay ally.
I will import what ever I need as I have to import everything else for the car.
Regards
Greg
Greg
20-25k counting the F1r kit?
you can get a complete 427 ls3 from tsp with
your choice of cam (custom probabally avail.)
custom piston set
total seal steel ring set
callies compstar rods
callies compstar crank
arp main studs
prc L92 heads with 71cc chambers and rocker arms and pedestals
arp head studs
ls7 lifters
for 9400 then buy a GMPP l92 carbed intake have injector bungs welded in use 80# injectors (maybe more) and a 4150 style TB with a carb hat < all that will run you around 1500ish then you have a complete motor and have around 10k for blower FMIC and computer and so on
that should easily get you to 1000+ hp
custom piston set
arp main studs
arp head studs
ls7 lifters
Thanks for the input on the short block recommendations, any thoughts on heads, manifolds and other bits I will need as i will need to put to gather a fuel system as well.
Greg
Greg
check these out https://ls1tech.com/forums/forced-in...ese-heads.html and also look at GMPP's new drag race heads idk if their 6 bolt though (i believe they are)
http://www.exoticperformanceplus.com...html?item=1715
http://www.exoticperformanceplus.com....html?item=151
Check out the above link to our 402 build. The LS3 would be similar.
http://www.exoticperformanceplus.com...Car.php?car=29
We basically used the above combination with off the shelf AFR 225cc heads on the CTS-V at this link. Check out the dyno sheet at the bottom of the link. The F-1A has a lot more left in it too. Bob
