Anyone running Precision 6262's??
Old Jun 25, 2009 | 10:48 AM
Boosted One's Avatar
Default Anyone running Precision 6262's??
***I messed up they are 6265's***
I have a pair and I'm building a setup, but I'm looking for a power number to help my converter guy to setup the converter.
Is anyone running these turbo's in a twin setup? What do you think? How soon does the boost come in? What is your setup?
Thanks,
Frank
Old Jun 25, 2009 | 01:47 PM
ls1king000's Avatar
I have a pair of the 6265's. Just got em shipped in today. Probably won't get the project together by next spring.
Old Jun 25, 2009 | 01:51 PM
Cool. Keep us updated! I plan on doing mine over the winter too.
Frank
Old Jun 25, 2009 | 02:43 PM
VINCE's Avatar
Shorty Director
I have no clue what they would make on a V8, but the 6262's have made over 700whp on EVO's and have run 8's. That's just one.
Old Jun 25, 2009 | 03:56 PM
black98ws6ta's Avatar
Ran 8's with spray or boost alone in a super light car?
Old Jun 25, 2009 | 05:06 PM
DrTurbo's Avatar
LS1TECH Sponsor
62mm units will easily make 1000rwhp. Maxed they will make around 1100rwhp on a V8.
Old Jun 25, 2009 | 05:07 PM
DrTurbo's Avatar
LS1TECH Sponsor
That is always the case with small displacement motors. Supra's make 1300+rwhp on boost only with a GT47-88 from Garrett. That same unit struggles to break a 1000rwhp on a V8. Efficiency is the key!!
Old Jun 25, 2009 | 06:52 PM
VINCE's Avatar
Shorty Director
Boost only.
2005 Evo VIII RS.. 1st Evo Street Car in the 8's
784hp on E-85.. 8.98 @ 156mph
Old Jun 25, 2009 | 09:27 PM
V-seriesTech's Avatar
Thanks,
Frank
Not sure how much of a help I can be but, I run two precision 67mm turbos on a 346ci setup running 11.5psi for now. I ran a 233/237-.649/.598-112lsa which isn't supposed to work well for boost. I run a 3 inch dual exhaust with no mufflers. AFR205's. My boost would come on really hard at 4500ish rpms. Not sure what would have happened if we would have swapped around camshafts. Either way, I was very happy with how the car ran,..and how strong it was. I ran a manual and without a roadrace tire or a drag radial 11 pounds would overwhelm the tires at any speed. ANy speed. I think you'll like the turbos, and they'll support plenty of power.
On 11.5psi and stock compression on 93 octane, 12 degrees of timing, 787/696 were the numbers. Take a little away for the auto/converter and hopefully you'lll have a relative idea.
Pulls were shut down at 6000rpm,...at 5500 fuel pressure would drop.
Not sure how much that helped.
Old Jun 25, 2009 | 09:49 PM
Shearer's Avatar
I'd guess 1200ish max with a large t4 hotside. I have quite a few guys making 700+hp, 2L's using a single 62, and couple guys have breached 800.
The car he's referring to is Mike's @ AWD. The car has some weight taken out of it. Take the slicks off and put some DOT's on and it's a legitimate street car.
Old Jun 26, 2009 | 12:36 AM
Still didn't answer my question, .
Old Jun 26, 2009 | 02:45 AM
VINCE's Avatar
Shorty Director
It was a boost only pass on E85.
Old Jun 26, 2009 | 01:48 PM
toretto's Avatar
on a not so great setup, a little integra made 650 whp @ 30psi.
GEt the billet wheel, it spins up slightly better, but mainly there is less deflection at high boost.
Old Jun 26, 2009 | 02:34 PM
Thanks for the input guys! Very helpfull. I think I'm going to go conservative and tell the converter guy it will make 650-700ftlbs. I'm getting pretty pumped about puting this combo together!
Frank
