My KYTP GT47-88 Manifold kit
#44
Oh man. with a 60+lb turbo, I’d be nervous to run that crossover through a lot of heat cycles. I’d be too nervous the weight+heat w/ no support would cause it to fail/crack/warp/bend.
:shrug:
:shrug:
#49
Well got the car out to the track had a few issues with the trans brake but best pass of the day was a 10.62 at 144 mph....1.992 60 foot. could not build any boost off the line cant wait to get the short times where they should be
#55
Got a t brake just wasnt workin, was only able to get about 2400 before it would push through the back brakes was havin an issue with rear calipers, just got some new ones on the way was a little hairy to drag it in top end
