Bad shifting (boosted car)
Old Jul 10, 2009 | 02:50 AM
Slow5.0.'s Avatar
Default Bad shifting (boosted car)
Old Jul 10, 2009 | 05:38 AM
stevieturbo's Avatar
shift faster ?
dont lift off ?
Old Jul 10, 2009 | 12:19 PM
Slow5.0.'s Avatar
You dont sound so sure about what your saying.
Are alot of you turbo guys seeing more mph with flat shifting?
Old Jul 10, 2009 | 12:49 PM
hawk584's Avatar
practice.. practice.. practice..
Old Jul 10, 2009 | 12:56 PM
Im very sure, I just dont understand your question.
If your shifts are slow...shift faster.
If you are concerned about boost dropping between shifts. Then either shift faster, or dont let off.
I'd have thought both be pretty obvious ? Although obviously there are risks with flat shifting. I personally wouldnt do it....I'm happy enough going easy when changing gear.
Old Jul 11, 2009 | 10:52 AM
caviness's Avatar
a4....
Old Jul 11, 2009 | 01:14 PM
MIGHTYMOUSE's Avatar
your 60 is holding you up much more than your shifting.
Old Jul 11, 2009 | 03:20 PM
elias_799's Avatar
your shifting is good. if you want the best shifting get a good auto.
Old Jul 12, 2009 | 07:16 PM
Super Slow SS's Avatar
I only saw 3 sec of the video and found the problem, its stuck to the right side of the dash (the pony) your in a mustang, it don't get any faster ..
im just kidding, but you have to try the obvious first .. as stated above.
Old Jul 12, 2009 | 07:55 PM
V-seriesTech's Avatar
Flat shift hommie.
Ou actually don't shift that bad from what I see but, you could be quicker. I learned how to power shift years ago in the same kind of car. Sometimes due to power/loss of traction we obviously can't powershift some of the lower gears like 1-2-or 2-3...but,..if you can't you really out to do it. Precious time is gained everytime you can as you mentioned you may be missing out on.
If you don't feel very comfortable powershifting a lower gear,...atleast try a 3-4 powershift. Every gear is important but, thats a crucial on. As someone said, practice practice practice.
Go somewhere,...somewhere you won't get arrested...and do some flat shift practices. Maybe start off on the 1-2 shift as your car should burn through both and it'll be easier on your drivetrain/clutch since your tires will probably be blowingoff lol.
I've broken multiple transmissions in the fox/sn95/f-body/y-body. Plan to miss some shifts. I don't think I have missed a gear racing anybody in a few years so, practice does help like you wouldn't believe. Just be prepaired to quickly lift off the throttle, should you miss a gear, or engage the wrong gear like soo many people have.
If all else fails, use the force.
Old Jul 12, 2009 | 08:12 PM
elias_799's Avatar
Originally Posted by V-seriesTech
Flat shift hommie.
or get an auto automatics and turbos where made for each other.
Old Jul 12, 2009 | 08:24 PM
I understand the value of an automatic but, I also understand the value of a well driven manual. I only know manuals,...and in my world, an automatic will never be an option. Better yourself(whoever) and your shifting skills. Believe me,...i'm tired of changing clutches but,...i'd rather do that, so I can feel like i'm in full control of the car. Autos,...I honestly don't feel as safe in. For the street,...which is where I am primarily on my ride,...it's crucial. The left pedal is my traction control.
Old Jul 12, 2009 | 08:27 PM
98Camarod's Avatar
60' is what needs work. Your 1/8th mph is 100 which IIRC you have a pretty light car and with that mph you should be in the high 6's in the 1/8th. How much boost are you running?
Old Jul 12, 2009 | 09:22 PM
WS6 SRT-8's Avatar
I agree. Try leaving harder.
Old Jul 13, 2009 | 01:13 AM
Slow5.0.'s Avatar
She has no more ford in her
Old Jul 13, 2009 | 01:14 AM
Slow5.0.'s Avatar
Turns out I had a significant boost leak on the car so I am going back to the track asap to find out how much it hurt me.
Old Jul 13, 2009 | 01:36 AM
elias_799's Avatar
i know what you mean about being more in control of the car, but the guy wants to go faster in a straight line, so an auto would be more then i deal for him.
Old Jul 13, 2009 | 10:32 AM
Zombie's Avatar
TH400 or 4L80 would make every shift a power shift, it's a great mod!
Old Jul 13, 2009 | 10:38 AM
tim99ws6's Avatar
Stop working the steering wheel so hard as well. I understand the car might be moving a little, but I think you're losing a little with your wandering as well.
Old Jul 14, 2009 | 04:35 AM
Jimmy P's Avatar
The shifting didn't look that bad to me.
