question about this cam ?
Old Jul 15, 2009 | 11:38 AM
NAVY's Avatar
Exclamation question about this cam ?
i am building 408 cid , AFR heads 225 i have this cam XER287HR-12 is this a good cam for Supercharger engine ( procharger F1-C ,14 psi ) or can you tell me a better one .
Cam Style: Hydraulic roller
Basic Operating RPM Range: 2,800-7,200 RPM
Duration at 050 inch Lift: 238 int./240 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.605
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.609
Lobe Separation (degrees): 112
can you help me
thanks
Old Jul 15, 2009 | 01:15 PM
ls1290's Avatar
Dumb Ass Vette Moderator
It is a OK cam. That cam on a 115 LSA or wider would be a good choice for a 408 CID motor.
Old Jul 15, 2009 | 02:26 PM
NAVY's Avatar
Smile
I think lsa 114
what The difference between 115 - 112 lsa ?
Old Jul 15, 2009 | 07:47 PM
NAVY's Avatar
ttttt
Old Jul 15, 2009 | 08:26 PM
venom ws7's Avatar
Check EPP Blower lots of cars are using it with procharger with 400+ci
Old Jul 16, 2009 | 04:44 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=679
Thanks, our 232/240 595/608 on a 115 works very well and doesn't bleed much boost out the exhaust valves. Bob
Old Jul 17, 2009 | 07:05 AM
NAVY's Avatar
my old cam for 402 ci 232 240 590 599 114 ,
Do you think this cam is not good for my now engine ?
thanks
Old Jul 17, 2009 | 07:13 AM
ls1290's Avatar
thanks
I think that cam is better than the 'new' cam. Though the old cam has slightly less intake duration, the wider LSA help out more.
Old Jul 17, 2009 | 09:26 PM
NAVY's Avatar
Thumbs up
thanks man to advise and Thank you for all
Old Jul 17, 2009 | 11:05 PM
STAR's Avatar
Yup, I agree!
